Are 1LE gauges rare?
Old Dec 13, 2009 | 03:51 PM
Epro's Avatar
Car: 95 Camaro Z28
Transmission: 4L60E w/ shift kit
Axle/Gears: 3.23s
I came across some 1LE gauges locally and picked them up, are they rare or anything?
Also, how much could I hope to get for them? They won't work with my 4th gen...
Old Dec 13, 2009 | 03:59 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: Are 1LE gauges rare?
Not rare at all. I have two sets of T/A clusters that have the same thing pictured above. Also that almost looks like a LG4 tach?
Old Dec 13, 2009 | 04:09 PM
Epro's Avatar
Car: 95 Camaro Z28
Axle/Gears: 3.23s
These shouldn't be, they're for a 1LE car... 1LE cars were all L98s. The redline is suppose to be a little bit lower than the regular gauges.
I mainly want to know how much they're worth.
Old Dec 13, 2009 | 04:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the 1le car should have a 140mph speedo and a 8k tach, and the same fuel and volt as any other bird,so nothing really special with what you have except for the metric oil and temp gauge, dont see then very often
also, there was so few 1le firebirds made, that i really doubt these came from a 1le car.
Old Dec 13, 2009 | 04:43 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Better get your info right before you say words like "all". NOT all 1LE cars were L98. There were also LB9/T5 1LEs. Also there is no such thing as 1LE gauges. Those are just ordinary firebird/trans am gauges.
Old Dec 13, 2009 | 05:10 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Yes, there's no such thing as 1LE gauges. They used the same gauges other cars used. The only thing usual about your gauges is that they are metric but there isn't anything "rare" about them. They aren't worth much.
Old Dec 14, 2009 | 01:26 PM
my82roc's Avatar
Car: 89 Iroc Convertible
All of the L98 camaros Ive seen came with a higher 5500 redline tach.Not sure about firebirds but I would figure that they would have a 5500 redline tach also
Old Dec 15, 2009 | 09:03 PM
houseofpain4_'s Avatar
Car: 86 T/A
Engine: 355
thoes are the same gauges my lg4 t/a came out with.
Old Dec 16, 2009 | 01:47 PM
Drew's Avatar
Did you get them off of ebay? "RARE 1LE GAUGES" sounds like something a nitwit seller would say to sell something average to an uninformed buyer.
Old Dec 16, 2009 | 02:18 PM
Twin_Turbo's Avatar
L98 a lower red line than the 5.0? I have both an L98 and a LB9 w/ G92 perf axle and 5 speed and it has a higher redline than all other 5.0s and it's the same as my L98 (oraange at 5K and red at 55) so all L98s have a higher redline than 5.0s except for the LB9 w/ those options.
The gauges you have are for a metric car, not just the oil/water gauge but also the volt, gas gauge metric cars have the fuel indicator with the filled circles where imperial units say 0 1/2 and 1
Old Dec 20, 2009 | 06:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
huh? i've never seen a bird with 0 1/2 1 for the gas level, both mine are filled /half-filled/empty circles, and every pod ive ever seen is the same way. Volts are the same in both metric and imperial, no?
Old Dec 20, 2009 | 06:45 PM
Twin_Turbo's Avatar
Not 100% sure on the firebirds but on camaro only metric cars had the filled circles
what about these
http://cgi.ebay.com/ebaymotors/86-92...#ht_500wt_1182
or this one
http://cgi.ebay.com/ebaymotors/86-92...ht_5526wt_1165
or maybe this one
http://cgi.ebay.com/ebaymotors/85-92...#ht_727wt_1165
this one??http://cgi.ebay.com/ebaymotors/82-84...f#ht_500wt_868
all those are empty-1/2-full none have the circles
Yes of course volts are the same, your 12v is the same as ours
Bubbajones_ya
Jul 6, 2024 08:32 PM
PurelyPMD
May 5, 2016 04:57 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
