weird panel, missing foglight connector?
Old Feb 15, 2010 | 03:35 PM
sparkplug619's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
Transmission: T-5 stick
i went to the junkyard today and picked up a few interior parts.
one of the things i picked up was the panel that holds the headlight **** and foglight switch.
The one I had originally in my 89 rs 305 has a hole for the headlight switch and where the foglight switch was supposed to be, there is another empty hole.
So the one I got had the hole for the headlights and the foglight switch below it, I went to put it all together but realized there is no harness or connector for my foglights. I checked under my dash in the wiring mess down there but cant seem to find it.
Can someone explain to me why my panel had 2 holes instead of a hole and switch, and why i cant find my foglight connector? I do have foglights
Old Feb 15, 2010 | 03:38 PM
Car: 1990 RS Camaro
Engine: 305 TBI
Re: weird panel, missing foglight connector?
whoa, I just checked out a few pictures of rs camaro interiors and noticed they have no foglight switch. So someone must have dremelled the second hole there. Then where is my foglight switch supposed to be? or am i not supposed to have foglights?
Old Feb 15, 2010 | 03:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Only IROC's were equipped with fogs. The switch can be seen in my Car Details below.
JamesC
Old Feb 15, 2010 | 05:35 PM
Car: 1990 RS Camaro
Engine: 305 TBI
ok so it was definitely dremelled.
Im gonna try to wire the fogs I have on my car to the fog switch I just got. RS with fogs!
Old Feb 18, 2010 | 02:34 PM
Car: 1990 RS Camaro
Engine: 305 TBI
ok check it out.. I was pulling off my side marker and noticed the foglights I had were plugged into something, which didnt make sense. RS, no foglights, but why are they plugged in? so I went back under the dash and unbolted my fusebox and moved it aside and found "A FOGLIGHT CONNECTOR." since my battery is dead I am unable to check if my fogs come on.
If I have an RS how come my fogs are plugged in and I found the fog connector? Whats going on?
EDIT: BTW, the fogs are coming out of the original harness and weren't wired in by someone. Ill take pics now and post em.
Old Feb 18, 2010 | 02:49 PM
JamesC's Avatar
Humm, the IROC grill has openings for the fogs. What type grill do you have?
JamesC
Drew's Avatar
JamesC is pretty close... You could get fog lights on the late Berlinettas, the LT, and maybe some 85-87 sport coupes, and they were optional on the Z28, standard on the Iroc. They were never even an option on the RS.
However people have been wiring fog lights into all Camaro's since about 1985. Chances are if you have fog lights, someone added them. The wiring is anyones guess.
Old Feb 18, 2010 | 03:00 PM
Car: 1990 RS Camaro
Engine: 305 TBI
Oh it could be possible someone wired them in but they just look so stock, The connector from the fogs goes to the original harness and the connector under the dash, iirc, comes out of an original harness, it would seem like too much trouble, especiall for someone who treated this car like crap, to wire in the fogs so stock.
Pics coming up!!
Old Feb 18, 2010 | 03:05 PM
Drew's Avatar
The OEM lights are unusual, the inside edge of the lense sticks out about twice as far as the outside edge, so they're shaped like a wedge of cheddar. If your lenses are flat, they're aftermarket. The stockers also have adjuster screws, like the ones on your headlights so they can be aimed up or down. Most aftermarket lights just have a hinged base bracket that tilts. Stock also have a huge steel mounting bracket instead of just a threaded mounting post.
Old Feb 18, 2010 | 03:14 PM
Car: 1990 RS Camaro
Engine: 305 TBI
looking at other pics of irocs with the fogs on, they are the same.
check it out
IN REFERENCE TO:
I have an 89 RS and this is an 89 iroc
uploading pics of wiring now
Old Feb 18, 2010 | 03:23 PM
Car: 1990 RS Camaro
Engine: 305 TBI
wow im an idiot
Old Feb 18, 2010 | 03:24 PM
Car: 1990 RS Camaro
Engine: 305 TBI
ok so I dont have foglights, but why do I have the connector? still trying to figure that out
EDIT: I believe I have a z28 front bumper
Old Feb 18, 2010 | 03:38 PM
JamesC's Avatar
I don't think that having the connectors/wiring themselves is particularly unusual.
JamesC
Old Feb 18, 2010 | 05:20 PM
Drew's Avatar
Just to clarify, and make sure we're on the same page here... The fog lights are circled in red, the grill is circled in green.
The front bumper on an Iroc or Z28 is exactly the same as a RS. Only the grill on fog light equipped cars is different. The RS you posted a pic of earlier had the louvered grill, someone just broke out both sides.
Attached Thumbnails weird panel, missing foglight connector?-a_1989_chevrolet_camaro_iroc_z28_convetible_2.jpg
Old Feb 18, 2010 | 05:45 PM
Car: 1990 RS Camaro
Engine: 305 TBI
ok thanks, just still learning.. The license plate holder on my front bumper said z28 so I just went by that
Old Feb 20, 2010 | 05:30 PM
black84z28-4spd's Avatar
all the license plate mounts say z28 from what ive seen. i had an 85 s with the same thing
Old Feb 21, 2010 | 04:01 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I believe in the later years at least, all the cars got the fog light wiring on the cabin side, but not on the outside. There seems to be a "Twilight Zone" in the firewall connector where the fog light switch wires disappear, and never make it out to the front of the car. I added the fogs to my 1992 RS, and used the factory switch. I wired it so that the factory switch got juice to 1) activate the little light in the switch when it's turned on, and 2) to just run low amperage juice out to the front. I then used a relay, and connected the fog lights from the battery through the relay. So, I flip the switch, positive turns on the green switch light, and runs under the hood to activate the relay, which then makes the connection between the battery and the lights themselves. That way, there's no high amperage wiring running into the cabin.
Old Feb 21, 2010 | 04:17 PM
Drew's Avatar
Technically if you roll back the clock, in 1985 that front end was specific to the Z28 and the Irocz. The matching license plate bracket was specific to the Z28/Irocz. When the 88 Camaro coupe, and later the RS rolled around they used the parts originally intended for the Z28. Also since the fog lights were optional on the Z28, there's not really a "Z28" and a "RS" grill, since either grill could be found on the Z28. To the best of my knowledge, Fog lights were never an option on the RS.
Old Feb 21, 2010 | 05:13 PM
JamesC's Avatar
Originally Posted by camaronewbie
I wired it so that the factory switch got juice to 1) activate the little light in the switch when it's turned on...
Just for general info, there were two switches, a three prong and a four. The former had no 'on' light.
JamesC
Old Feb 21, 2010 | 06:23 PM
Car: 1992 RS
Engine: Carbed 350
Interesting James C!
By the way - you really know too much about these cars! (Not that it's a bad thing mind you)
Old Feb 21, 2010 | 06:32 PM
JamesC's Avatar
I'm retired. I have no life
JamesC
Old Feb 23, 2010 | 12:10 AM
Car: 1990 RS Camaro
Engine: 305 TBI
JamesC
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
