button in center console...?
Old Mar 23, 2010 | 12:47 AM
motoman9790's Avatar
Car: '86 z28
Engine: 305tpi summit1101 cam, slp runners
stupid question, but what is the slider button in the center console between the window switches for?
Old Mar 23, 2010 | 12:55 AM
Daddy-o85's Avatar
Car: 92 Camaro RS
Engine: 3.1
Transmission: 5 Spd
Re: button in center console...?
It should pop the rear hatch.
Old Mar 23, 2010 | 12:57 AM
Car: '86 z28
is there any way i can get a wiring diagram for the electric hatch? i bought the 86 z28 last week and i is all disconnected...
Old Mar 23, 2010 | 12:59 AM
z28_87Camaro's Avatar
Car: 1987 Z28 / 1988 IROC-Z
Engine: 305 LG4 / 305 LB9
Transmission: T5 5spd
Axle/Gears: 3.42 / 3.08
"Should" being the key word there. haha. I'm on my 3rd, ThirdGen and none of them had a working hatch slider. I've just gotten so use to opening it up with the good ol' key.... I'll fix it one of these days. There's multiple threads here with good instructions on how to do so if yours doesn't work either.
Good luck!
Old Mar 23, 2010 | 01:13 AM
Car: '86 z28
thanks! one more thing, what color is the constant power radio wire? i am losing all my presets every time i kill the car...=(
Old Mar 23, 2010 | 01:24 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Good luck!
funny i never had a problem in any of the 3 3rd gens i've owned
Old Mar 23, 2010 | 01:31 AM
From what I recall, Orange is constant, Yellow is ignition. Someone correct me if I'm wrong.
Well, apparently I suck! haha. Ah well. I'm not worried. Sweet deal for you though. Honestly, I couldn't even tell you how that switch works, or have ever seen it working on a thirdgen. One day... just like I say for everything else. lol.
Old Mar 23, 2010 | 01:35 AM
here, located these diagrams to give you a hand.
1982 to 1988 Stereo wiring diagram
1988 to 1992 Stereo wiring diagram
Old Mar 23, 2010 | 07:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Maybe something in the link to follow:
http://www.austinthirdgen.org/index.php?pid=19
JamesC
Old Mar 23, 2010 | 07:33 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
These things can be wired directly (assuming your solonoid hasn't gone bad) but I don't like them on the center console that way, there's too big a chance you will hit it while driving. I installed mine to the area right next to the hood release. It's just a 12V power source to the switch, and then the switch continues that right back to the hatch. really simple
Old Mar 23, 2010 | 07:54 AM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Good luck!
lol for all the maros i looked at including mine the slider always worked, however if you used the key to open the hatch the motor releases it but gets stuck and you need to jimmy the latch for the motor to pop up then it can pull hatch back down
Old Mar 23, 2010 | 12:03 PM
aldaran's Avatar
Safety feature, hatch will not open when gear is in "Drive". You will need to put it in "Park" then it will work again. At least that's the way my 88 Camaro is.
Old Mar 23, 2010 | 12:10 PM
58mark's Avatar
yes, i know that. i was bringing it up in case he wires his up with direst power like mine.... no safety feature then
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Ed1LE
Sep 30, 2018 09:14 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
