Flashlight pics
Old Apr 5, 2010 | 11:36 PM
JackRs's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
Flashlight pics
Just pulled a camaro flashlight from the local jy and im in the process of cleaning it up and restoring it. If anyone has pictures of it, especially internal that'd be great. Thanks.
Old Apr 5, 2010 | 11:57 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Re: Flashlight pics
mine got stolen...
Old Apr 6, 2010 | 01:01 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: Flashlight pics
Goodluck.I cleaned the hell outa mine and it still wouldnt work.I think my contacts were just way too corroded.If you do get it to work you may want to put an led light in it cause those things are worthless as a light when they do work.I`ll try to get some pics up for you.
Old Apr 6, 2010 | 07:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Flashlight pics
Post #19 of the following link:
https://www.thirdgen.org/forums/faq-...oth-types.html
After thoroughly cleaning mine and using dielectric grease on the parts, my flashlight has worked for several years without issue.
JamesC
Old Apr 6, 2010 | 08:22 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Flashlight pics
I soaked both my Firebird flashlight and my Camaro flashlight internals in CLR and it cleaned it up pretty nicely, after that, i used my dremel to clean and polish the parts, and like above, used some electrical grease and did an LED conversion to it, and they work like a charm, bright as hell too with the LED
Old Apr 6, 2010 | 08:28 AM
JamesC's Avatar
Re: Flashlight pics
Originally Posted by 84redta
...and did an LED conversion to it, and they work like a charm, bright as hell too with the LED
Is the conversion simply swapping in an LED? If so, what LED did you use? Details, please.
JamesC
Old Apr 6, 2010 | 08:53 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Flashlight pics
JamesC
You can go this route if you have the cash:
http://www.led-replacement.com/l222.html
If you just solder in an LED, you'll fry the battery if you don't also put a current limiting resistor in the circuit.
Old Apr 6, 2010 | 03:13 PM
JackRs's Avatar
Car: 1991 Camaro RS
Re: Flashlight pics
Sorry Posted Twice
Old Apr 6, 2010 | 03:16 PM
JackRs's Avatar
Car: 1991 Camaro RS
Re: Flashlight pics
JamesC
Thanks James thats what i'm looking for, it just looked really blurry. I'm looking for a nice high quality picture of nice guts to see what i need to clean up and replace, sort of a monkey see monkey do.
e
Is there a write up for this? I have no idea how to solder or any knowledge of circuits.
Old Apr 6, 2010 | 04:17 PM
JamesC's Avatar
Re: Flashlight pics
It's a very simple design. The guts are all held in place so that when you separate the two halves all will stay in place. BTW, the tabs that secure the halves are easily broken.
JamesC
Old Apr 6, 2010 | 07:24 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Re: Flashlight pics
You definitely need a basic knowledge of electrical circuits to do this conversion.
You can use this formula in this tech article to calculate the resistor value you'll need.
https://www.thirdgen.org/leddash
Edit: Here's a circuit that is similar to the circuit in the flashlight:
http://www.solarsam.com/d-links/battery_circuit.html
Just substitute the LED for the bulb. The resistor will go in the part of the circuit that goes from the "+" side of the battery to the LED.
Edit: Here's a better diagram:
http://en.wikipedia.org/wiki/LED_circuit
Old Apr 6, 2010 | 08:40 PM
JackRs's Avatar
Car: 1991 Camaro RS
Re: Flashlight pics
Heres my problem. I dremel cleaned all the metal inside, besides the switch because i couldn't remove it. When i flip the switch on and off it doesn't change anything i'm pretty sure i'm missing a piece. Is there any way to MacGyver a solution? Here are some pics of what i'm talking about.
Old Apr 6, 2010 | 11:30 PM
JackRs's Avatar
Car: 1991 Camaro RS
Re: Flashlight pics
Just because this is a tech article i'll post my own answer.
Here are the guts for anyone who wants to see where things go.
(just save and rotate.)
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
ndndndnd
Sep 28, 2015 08:00 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
