90 camaro lower dash pad
Old Apr 9, 2010 | 04:11 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
does anyone know where i can find the bolts or screws that hold the dash pad up? the PO lost one and its bugging me only having one in there cause it saggs, so anyone know where i can find these? its a torx
Old Apr 9, 2010 | 04:12 PM
Necrolust's Avatar
Car: 1991 Camaro Z28
Engine: 350 T.P.I.
Re: 90 camaro lower dash pad
Try going to the junk yard and find the camaro that still has the dash in it and take them off of that
Old Apr 9, 2010 | 04:26 PM
Engine: L31 350
been there and done that, most the camaros and firebirds have the steering coloum ripped out of them, so meaning that pad is gone, also meaning that screw/bolt is gone....
Old Apr 9, 2010 | 05:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Just go to local hardware store and match up with new sheet metal screws. You might not get torx, but phillips is available, and you can't see the heads anyway (unless your upside down in the car).
Old Apr 9, 2010 | 05:43 PM
Engine: L31 350
sheet metal screws? your kidding right?, not to sound like an *** but i would just prefer to have the original and not have something...like that holding it up..., thanks for the advice though
Old Apr 9, 2010 | 06:00 PM
Car: 1992 RS
Engine: Carbed 350
Well that's all they are, pan head sheet metal screws with torx heads. I'm not suggesting you get little small sheet metal screws and drill new holes into the metal framing. Get large (I think they are #12 or #14 size) screws - they screw into those metal clips that clip around a larger hole in the framework.
Old Apr 9, 2010 | 06:03 PM
Engine: L31 350
ok, ill look into that
Old Apr 9, 2010 | 07:12 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I'm sure I probably have a spare set of those screws (5 total) hanging around somewhere
but I'd go with camaronewbie and hit the store. You can get them probably cheaper than the cost of sending these to you. If for some reason you can't get what you want let me know
Old Apr 9, 2010 | 07:20 PM
Engine: L31 350
2 are screws and 3 are bolts, but yeah im gonna do what newbie said
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Street Lethal
Aug 14, 2015 08:25 PM
Vintageracer
Aug 11, 2015 08:13 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
