solution to a brighter interior and interior gauges?
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
hi ok i pulled over all the covers to my instrumental gauges to where you could take of the guages and all because i was going to remove all the bulbs and replace because mine are extremly dim. well i did all that and found out that you dont get to them that way. so how do i get to them? also i was curious on how i could get the interior to light up a bit more iv replaced the bulb overhead light with a new basic bulb and iv cleaned up the white cover as good as i could with plastic polish. its a tad bit lighter but not much so what is something else i could do? thanks. btw i found a thread about painting one of the pieces of the intrumental parts silver. is this pretty simple to do?
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: solution to a brighter interior and interior gauges?
the bulbs mount from the back of the cluster. you have to remove the 4 bolts holding it in and pull it out all the way to get to the bulbs. it takes like a 1/4 to get them out.
Engine: 305TPI
ok so if i understand you right i have to remove everything other then the gauges and there should be those bolts? are they in the very corner?
Car: 91 Camaro RS
no, you have to pull the cluster (the white plastic holding the gauges in) i know on 90-92 theres 4 bolts, 2 on top and 2 on bottom, that hold the cluster in.
heres a pic of an 84 (i think) gauge cluster. you can see where the bolt holes on the top are.
edit: i guess it helps if i attach the pic....
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Two nuts in the earlier clusters. Here's a removal how-to (second para):
https://www.thirdgen.org/forums/faq-...-fix-pics.html
Painting the bezel is included. High-intensity bulbs in the gauges or perhaps LED's. LED's in the dome light. The following link provides the idea:
https://www.thirdgen.org/forums/inte...-overhead.html
JamesC
JamesC
Engine: 305TPI
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The entire white housing with all guages in tact mounted to it comes out as one unit, then the bulbs are accessed from behind - you don't take the individual guages out of the white housing.
For the dome, get a led array from ebay - I think mine has 30 leds and it's very nice and bright at night.
Car: 91 Camaro RS
if you really want a much brighter bulb in your instrument panel, take a look at superbrightleds.com, they have direct replacement leds that should brighten things up quite a bit. i think you can even get colored ones for a more custom look.
Engine: 305TPI
Car: 91 Camaro RS
if you look at the pic i posted earlier, you can see where the two bolts mount the cluster at the top. in the big squares just above the big circular light holes. since you have a cable driven speedo, you might have to disconnect the cable. i dont know how much slack they have or how far you can pull the cluster out with it attached.
Ghettobird52
Jul 5, 2024 11:18 PM
