2nd Camaro console clock doesnt work..whats going on?
Old May 15, 2010 | 10:34 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Ok ive tried two of these things now and neither of them worked. I have the three wires connected correctly i think (not really sure how i could F that up). The first clock would work for about 15 minutes and then stop. Then i could disconnect the power (pull the fuse) and reconnect it and it would work again for 15 minutes and then stop. The second clock does the same thing but instead of 15 minutes its more like an hour or two (havent really timed it). So..is it something im doing or is it the nature of the beast and i just have to keep looking until i find one that actually works 24/7?
Old May 15, 2010 | 10:47 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Re: 2nd Camaro console clock doesnt work..whats going on?
It's very common for the console clocks to have problems. However, they usually either work or they don't. The only time I've seen one with a problem like you're having the problem was that the second hand was hanging up on one of the other hands sometimes. You may want to check that.
Old May 15, 2010 | 10:55 PM
subroc's Avatar
Engine: 355 TPI
What is the best way of going about fixing that if that ends up being the cause of the problem? I heard the 2nd hand on these is delicate and i dont wanna break it. I guess careful is just the name of the game here huh...
Old May 15, 2010 | 11:15 PM
subroc's Avatar
Engine: 355 TPI
Ok just went and looked at the clock in the car now. The second hand, minute hand and hour hand are no where near eachother where it stopped. I ever so slightly tugged on the adjuster and it started right back up again. I dont know what to make of that. Do i have a working but finicky clock that needs to be cleaned or something or is it really busted.
Old May 16, 2010 | 07:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Several years ago, I experienced a similar problem. I was ready to send the clock in for repair, but in advance of that, I pulled the clock, blew it out with compressed air, then doused the innards with WD-40. I manipulated the hands for several minutes and stuck it back in. Still works and keeps good time.
Oh, with the clock removed, I polished the plastic face. Came out very nice, if I say so myself.
JamesC
Old May 16, 2010 | 07:57 AM
subroc's Avatar
Engine: 355 TPI
Originally Posted by JamesC
Several years ago, I experienced a similar problem. I was ready to send the clock in for repair, but in advance of that, I pulled the clock, blew it out it compressed air, then doused the innards with WD-40. I manipulated the hands for several minutes and stuck it back in. Still works and keeps good time.
Oh, while I had the clock out and polished the plastic face. Came out very nice, if I say so myself.
JamesC
Where did you spray the wd-40....all over the inside? I would think that would be bad for the electronics. Also did u pull the face to do it or just the plastic face and spray around the back of the metal face?
Old May 16, 2010 | 08:05 AM
JamesC's Avatar
In my fading memory, the innards/clock works were visible. I don't recall taking anything apart, but....
JamesC
Old May 16, 2010 | 08:13 AM
subroc's Avatar
Engine: 355 TPI
JamesC
Yea that would make sense. When u take off the plastic face you can see around the metal face to the innards. There is a gap all the way around.
Old May 16, 2010 | 08:20 AM
JamesC's Avatar
Good! I thought I'd jumped off the deep end for a moment. Anyway, the 'fix' has lasted a number of years.
JamesC
Old May 16, 2010 | 09:31 PM
my82roc's Avatar
Car: 89 Iroc Convertible
I currently have about 6 console clocks and on occasion have encountered the same problem.The one installed in my 89 iroc vert works flawlessly.The one installed in my 86 iroc works ok but it has problems on hot days.When parked for awhile with windows up it will just stop after a couple of hours.I have to bang on it to get it started back up.Others I have used the WD-40 as James C stated above.It works well to free up the mechanics as most clocks have been sitting for a bit of time unused in cars that end up at the junkyard
Old May 17, 2010 | 05:27 PM
subroc's Avatar
Engine: 355 TPI
Im not going to jinx myself and say that the WD-40 fixed it but yesterday i blew the clock out with compressed air and sprayed some WD on all the gears trying to steer clear of the actual electronics. Well i plugged it in last night and its still working as of 6:30 tonight. So thats the longest ive seen one of these things go for so far.
Old May 17, 2010 | 08:50 PM
my82roc's Avatar
Pretty much every console clock ive found has been in working condition.I installed one in my old 82 camaro,pulled it out before I sold the car and put back the original console top.It now lives on in my 89 iroc vert.The console clock is one of the coolest options on a 3rd gen camaro IMO
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
Firebird sweden
Aug 16, 2015 05:02 PM
TheJoeY88
Aug 13, 2015 06:51 PM
