Fourth gen interior in a 92 project
Old Jul 27, 2010 | 09:26 PM
Badrs2810's Avatar
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
Hi, I have a 92 rs I like my interior but not 100 percent happy. I loved my 95 z28 interior, so I'm going to swap the entire interior in my third gen for fourth interior. I took my model car which is a third gen and made it identical to every plan I want to do to my car body and engine and interior wise. Anyways, what's the easiest way to go about taking the 92 dash out and putting the fourth gen one in, that's what I'm going to start with. Thanks for your time, look forward to your responses.
Old Aug 1, 2010 | 09:05 PM
krwyellowz28's Avatar
Re: Fourth gen interior in a 92 project
Use the search function... but this will get you started:
https://www.thirdgen.org/forums/inte...dash-swap.html
Old Aug 1, 2010 | 09:26 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I just swapped a 97 Dash in my 88, depending on which year gauges you end up using, the wiring may be different. If you decide to go with the 97-02/98-02 gauges, let me know and I will make a diagram of what wires get spliced where. I found the wiring on the "wiring guides" to be slightly off.
Old Aug 1, 2010 | 09:38 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
I'm glad someone just did so I have fresh info. A few questions; how long it took, how much you spent in fourth gen parts, and the wiring? Was the wiring easy? That's my biggest stall right now in proceeding. I have made camaros fast but new to body and interior mods, so bare with me. I haven't bought anything yet, don't have a clue as to what price would be good, so info on that would help a lot. I like the 97 look so I might look into that, fairly simple? The wiring diagram you were talking about could help too, thanks for
time and responses
Old Aug 1, 2010 | 09:57 PM
I got the whole dash, the gauges, and most trim for $100. Also grabbed the connector the hooks into the gauge cluster and about 6" of wire so I had enough to splice to. Took me about 2 days to remove my old dash, cut/splice the old cluster wires into the new connector, and mount the new dash. My dash is not complete yet, but it is bolted in and all of the wiring is correct, so it is functional.
I am not sure of the 90-92 wiring for the gauges is any different than mine, I would assume that it was. But it shouldnt be too hard to sit down with a notepad and make a schematic to follow, which is what I did.
Old Aug 1, 2010 | 10:03 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
100 bucks and I haven't jumped on it yet, what the crap! Lol, where did you purchase you're from? As far as wiring, was it a color match on splicing or what?
Old Aug 1, 2010 | 10:07 PM
I actually got it locally, I got a good deal on it, too.
Honestly, you should expect to pay more. Also, the top dash pad is what will cost you about $100 alone, I didnt get that part yet, though.
Most of the wires are pretty much a color-matching deal, but some are not! Absolutely dont just splice similar colors together, something will not work.
Old Aug 1, 2010 | 10:14 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Well I look at it this way, if there is one deal out there, there is another alike, lol. Maybe I'll get lucky! Personally I'm looking for a whole car, with or without motor and tranny, just incase. I know nothing bout wires, unless it is car audio which is a no brainer, should have paid more attention in electronics class. 2 days is a good time span, works for me
Old Aug 1, 2010 | 10:21 PM
I am not exactly a wiring guru, myself. Basically, If I did it, you can do it. It just LOOKS, and SEEMS harder than it actually is. When you decide to tackle this swap, don't hesitate to ask me any questions.
Old Aug 1, 2010 | 10:25 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Absolutely, just need to go for it I guess. But, when I find everything and start, any ?s I'll def hit you up, thanks man
Old Aug 1, 2010 | 10:38 PM
Not a problem.
Old Aug 2, 2010 | 03:29 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Anyone selling a 97- 02 camaro interior, dash, seats, door panels, trim, etc. and you live near Wilmington, nc? I'm looking for a good deal, any info hit me up, thanks
Old Aug 3, 2010 | 06:59 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Had a question, you actually got the 97-02 guage cluster to work? What year cluster did u use and did it come out of a firebird or camaro?
Old Aug 3, 2010 | 08:29 PM
Camaro.
I wired it properly, but my fuel sender is broken, and I have no oil pressure, or temp senders in the motor. I am swapping in an LT1 soon, so they will work when I do.
Old Aug 3, 2010 | 08:38 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Well if I were swapping for an ls1 it would be fine too right? Not now but in future, but until then what cluster should I get?
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
neekolzun
Aug 24, 2015 04:59 PM
Linson
Aug 21, 2015 02:12 PM
