Turn Signal Lever problem
Old Jul 31, 2010 | 10:06 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
My car has a problem with the turn signal lever sometimes. What it will do is when I use my right turn signal, it will cancel out sometimes right after I turn it on, before I even make the turn. It only does this for the right turn signal, but not the left. What needs to be done to fix this?
Old Jul 31, 2010 | 11:58 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Turn Signal Lever problem
There is a plastic piece inside the steering column called a "cancling cam" - sounds like it's got a busted tooth or something on it. I don't know 100%, but I think you have to remove the steering wheel to get to it and fix/replace it. It might just need realigned or something, or it might be broke and need replaced.
Might check local JY's for a 3rd gen with steering column, then grab a "free rental" steering wheel puller from advance/autozone/whatever and go "practice" getting one out on the JY car, then you'll get one to replace, and you'll see how it's done on someone elses car
Old Jul 31, 2010 | 12:05 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following link may provide some helpful pictures:
https://www.thirdgen.org/forums/susp...-steering.html
JamesC
Old Aug 1, 2010 | 02:44 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
you just have to reposition the canceling cam itself to a position closer to the left of your wheel and reassemble.
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
