Metal box under right side dash speaker....?
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Here's the deal after getting my car I found out a PO had some sort of electronic crap in it, because there is a whole mess of wire that doesn't belong and the speakers weren't stock(or decent speakers o.O?) anyways just found a nice big chunk of it under the steering column when removing the dash...would like to remove all this crap as I have no idea what it went to and don't want someone else's hackjab wiring in my car....
Found a metal box mounted vertically to a bracket underneath rightside in dash speaker, also noticed the firewall has vents underneath of it, someone tell me if it belongs there, kind of looks like an ECM box so I am wondering if PO relocated it or something....
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Metal box under right side dash speaker....?
Sounds like the ECM or the Cruise Control Module if it's pass side - is it the same box you see from under the dash on pass side? Get us a pic if you can.
The rest might have been hacked speaker wire, or door entry - mine had keyless entry installed by the PO that actually works, and works great - pops the door locks and the trunk!
Engine: 3.8, 3.4
Yeah but isn't the ECM supposed to be driver side underneath steering column I always thought?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If it's silver, mounted vertically, measures about 6 inches wide,about 9 inches long, and 11/2 inches thick and has a bunch of wires plugged into the bottom end , it is without a doubt your engine computer and by no means excess stuff and that is it's normal location
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
If its the ecm,it will have 2 plugs on one end,one will go to the fender connector on the right side near kick panel,and the other will lead back into the interior harness.
Alicat.
Alicat.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Terrell351
Jun 13, 2021 01:13 PM
