Two Important Questions.
Old Aug 23, 2010 | 10:46 PM
LastKnownOne's Avatar
Car: 90 Camaro RS
Engine: 5.0 305 8cylinder
Axle/Gears: Stock Gears
1. What does the Dashboards symbol "^ Shift" mean? I have searched and googled but cant find it. l
2. I have read that people paint the area, where their dash lights hookup in the gauge cluster, white so it can reflect the Led light much better. What kind of paint and where exactly would I paint?
Old Aug 23, 2010 | 11:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Two Important Questions.
It's a shift indicator for the manual shift cars telling you optimum shift point for fuel mileage
Old Aug 23, 2010 | 11:20 PM
Car: 90 Camaro RS
My car is a automatic though, it lights up whenever I press the gas. Should I just ignore it then?
Old Aug 23, 2010 | 11:26 PM
joepackersrock's Avatar
Car: 1991 RS Camaro
Engine: 400 Smallblock
Your car was most likely originally a manual, you can check your rpo codes to verify.
And yes dont worry about it doesnt have any significance now
Old Aug 23, 2010 | 11:27 PM
Car: 90 Camaro RS
Where can I find these numbers and where do I use them to check?
Old Aug 23, 2010 | 11:40 PM
Car: 1991 RS Camaro
what year is your car? Earlier third gens usually have them under the armrest lid on the center console. Later years had them under the lid of the glove box in the rear hatch area. It's just a sticker with a bunch of codes on it, get pen and paper right em all down and then use the rpo checker on the homepage of this site and it'll tell you what equipment your car left the factory with.
Old Aug 24, 2010 | 12:07 AM
Car: 90 Camaro RS
Ive seen that sticker in the middle consol. Thanks. So any idea about the paint?
Old Aug 24, 2010 | 01:53 AM
little8camarors's Avatar
Car: 92 Camaro RS TTop,91 Camaro RS vert
Engine: 305 TBI V8
just a note: double check the vin number on the rpo sticker to see that it matches your vin. no telling if someone swaped out the console or rear panel unless your the original owner other than that. And for your second question, I don't think they paint them but buy a gauge inlay kit that you place over the black. Still requires opening up the cluster and removing the needles I believe. The inlays have the numbering on them and if you were to pain im sure you'd get paint on some and tring to get it off would probally make it worse.
Old Aug 24, 2010 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by LastKnownOne
My car is a automatic though...
An easier answer is that the cluster from a manual car was swapped into your car. If the bulb is troublesome, yank the cluster and remove the bulb. If you choose that path, while the cluster is out, you might repair the trip odometer if it's broken--and most are:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
Here's some ideas for painting the cluster:
https://www.thirdgen.org/forums/body...r-cluster.html
JamesC
Old Aug 26, 2010 | 02:16 AM
RavenTA's Avatar
Car: 87 Trans am
Transmission: 5 speed
If your car has a shift light there is 2 options
either you have a gauge cluster out of a manual car, or your car was a manual from factory,
If your car is factory automatic i dont even think it has the plug in that goes into the cluster for a shift light, So im guessing it came from the factory manual
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
apie2546
Sep 20, 2015 01:03 PM
