Loose air vents
Old Sep 5, 2010 | 06:50 PM
WHTrunner's Avatar
Car: 1986 Z28
Loose air vents
I've got another dash that I'm preparing to put in my camaro. But the air vents are all loose and kinda flop around. How can I remedy this problem?
I've got all the vent louvers pulled out and cleaned up. It looked like there was some sort of foam in there to prevent them from flopping around. I was thinking about putting some thin weatherstrip back on them in the same spot, but I thought that someone here might know of something better to use.
Old Sep 5, 2010 | 06:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Loose air vents
https://www.thirdgen.org/ventfix
Old Sep 5, 2010 | 07:10 PM
WHTrunner's Avatar
Car: 1986 Z28
Re: Loose air vents
@.@ Oh.
I think I have some velcro somewhere. Thanks!
Old Feb 23, 2014 | 04:58 PM
Van Nuys born's Avatar
Car: 4/89 IROC Z28 G92 -
Engine: LB9 TPI
Axle/Gears: 3.45
Re: Loose air vents
Just did this repair on all six dash vents..... now their all nice and snug and stay where you put them.
I didn't use velcro but a dense 1/16" foam rubber I picked up at a craft shop in a sheet 10 x 12".
I got 1/8 " also but didn't need it. It's black and I used two way tape to adhere it to the vents. Just cut half circles and stuck it where the old foam was.
They can be a bit tricky to get out especially the lower small ones. I used a screw driver to pry up on the center buttons that hold them in place being carfull not to break the plastic.
The smaller ones I worked out from top and bottom together. I wet them with a little spit to slide them back in.
Do this repair if yours are loose... you'll be glad you did.
Old Feb 23, 2014 | 07:28 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Loose air vents
I put small x-section o-rings of the proper size on the vent pins.
Old Feb 23, 2014 | 07:34 PM
Engine: LB9 TPI
Axle/Gears: 3.45
Re: Loose air vents
I looked in my O rings also as a possible solution ..... but went with the foam.
What ever works I guess....
Old Jan 16, 2017 | 04:11 PM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
Re: Loose air vents
Old Jan 18, 2017 | 03:28 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: Loose air vents
I also did the o rings on the vent pins. Picked them up at home depot. The hard part was carefully removing the vents as not to break any of them or the surrounding plastic. Once was all said and done, fantastic.
83 Crossfire TA
Jan 3, 2016 01:26 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
TBRays98
Sep 6, 2015 05:05 PM
middian
Sep 5, 2015 01:42 AM
