GAUGE SWAP PROBLEMS
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
GAUGE SWAP PROBLEMS
I have an 84' Z28 w/85 mph cluster. Swapped it out for the 145 mph cluster. Everything seems to work, except the temp guage. It works, but it keeps telling me that I'm overheating. I WANT TO KEEP THE ORIGIONAL GUAGES!. I know about the guages being inaccurate, however, they used to work at some point, so how to check the guage?
Is there some different sending unit or some other thing I am missing to make the upgrade accurate? The car is not running hot, but it is telling me it is. Different sending unit? Faulty wiring?
BACKGROUND:
new gauge (from junkyard, I have 3)
new sending unit
new coolant temp sensor
new thermostat
new waterpump
new belts
new hoses
raditator 6 yrs old, but no leaks and has been flushed and cleaned
So it is most likely not mechanical.
BACKGROUND:
new sending unit
new thermostat
new waterpump
new belts
new hoses
Car: 1991 Vert Z28
Engine: 305... LS1 waiting to drop in
Transmission: 700-R4... soon 4L60E
Axle/Gears: 3.08 posi nine bolt
Re: GAUGE SWAP PROBLEMS
well what year did the 145 cluster come out of? its possible the 145 cluster car calls for a different temp gauge sending unit
Car: 1984 Z28 T-TOP
not sure. swapped them out a few years ago. how would i find this other sending unit? I would pay $10.00 to just try that out. this gauge thing if frustrating.
Car: 1991 Vert Z28
well i did a quick search and found that different year camaros use different part numbers for the temp sensor. i would go and try a sensor for a different year camaro
Car: 1984 Z28 T-TOP
I am willing to bet it is either a different sender or something in the wiring eg. short or loose connection. How do I test the wiring to see if it is good?
Car: 1991 Vert Z28
haynes manual doesnt say anything on how to test the circuit. try unplugging the sensor and see if the needle position changes when the key is on.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Can you swap the original temp gauge into the 145mph cluster?
That way you wouldn't have to buy anything and it worked with what you already have.
Car: 1984 Z28 T-TOP
I think it is the same temp gauge in several MPH variations.
Car: 1984 Z28 T-TOP
2 OTHER IMPORTANT NOTES:
My ECM is disconnected, I believe, would that effect the temp gauge?
And what does the coolant sensor do in a belt driven fan model?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There are some electrical issues between clusters (which is why I always suggest simply swapping the speedo head):
https://www.thirdgen.org/forums/inte...atability.html
JamesC
JamesC
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've used the same type of temp sending unit on countless LG4's, LO3's, LB9's and many other 'mutt' engines I've built over the years. The only difference I've ever noticed is when swapping from a dummy-light temp "switch" to a gauge "sending unit".
Jim's right, Probably a problem with the printed circuit on the replacement cluster,................ Re-install the original cluster with the 145 Speedo head !
Car: 1984 Z28 T-TOP
I can't I did the swap years ago. How do I know if I have a gauge sender?
Ghettobird52
Jul 5, 2024 11:18 PM
