frustrating trunk pull down rebuild
Old Nov 23, 2010 | 06:52 PM
  #51
Gabaloo's Avatar
Re: frustrating trunk pull down rebuild
well its fixed, only had to replace every thing lol.
it was probably the strike sensor, which happened to be the last available piece to replace. of course
Old Nov 23, 2010 | 07:06 PM
  #52
grassyflats's Avatar
where did you buy a new strike sensor?
Old Nov 23, 2010 | 07:13 PM
  #53
Gabaloo's Avatar
i bought everything from lon's site.
Old Nov 23, 2010 | 10:03 PM
  #54
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
No the two styles of pull-down are not interchangeable (unless you cut and swap the mounting from a donor car). It could be that the unit has cycled down midway. If that is the case you'll need to cycle it down the remainder of the down cycle. That is donw by pressing on the striker-sensing swith which is just in front of the latch. There are three wires cominf from it. You'll need to press on a small black paddle which is the actual switch lever. Press and hold it down, the unit should cycle down. Once it reached the bottom of th down cycle you'll hear a CLICK which is the reversing switch being tripped. Release the switch and it should cycle all the way up. For anything else check the TECH article I wrote on this site. You'll refer to pages 3-4 for your 88-91 style pull-down unit.
https://www.thirdgen.org/tech/hatchpulldown.pdf
Lon
Old Nov 23, 2010 | 10:48 PM
  #55
the thing is... it does do as described...
can ya sell a new unit 50% off for Xmas?
wait a second let me get my hammer!
Old Nov 24, 2010 | 01:13 AM
  #56
lonsal's Avatar
Put it on your "Christmas Wish List" when you write to Santa.
Be aware that using a hammer on it will cut way back on the refund you'll get for returning the used core.
Lon
Old Nov 24, 2010 | 04:09 PM
  #57
Lon
I figure it is worth the investment considering the professionalism involved
and the lack of amateur headache.... thanks Lon
you have a great deal on the core ...extremely low mileage and unhammered XD
Old Jan 4, 2011 | 04:28 PM
  #58
the new unit works great ...thanks Lon -happy new year!
Old Aug 22, 2011 | 08:21 PM
  #59
JAYBIRDPHEONIX's Avatar
Car: 1987 FIREBIRD
Engine: 305 CARB (FOR NOW)
Transmission: WC BORG WARNER T5
Axle/Gears: 327 posi disc
SHOOT ME I HATE WIRES I HATE ELECTRICAL ALL I WANNA DO IS TEST THESE THINGS AND BLEGH....ANY WAY TO BENCH TEST THEM? I DISCOVERED SOME WIRING ISSUES WITH MY FB WHICH I WAS ALSO USING TO TEST THEM....BUT NOW THE PROBLEM IS BIGGER THAN I THOUGHT
ydnar417
Sep 23, 2015 05:57 AM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
86IROC112
Aug 31, 2015 07:00 AM
86White_T/A305
Aug 17, 2015 12:16 AM
hokis
Aug 9, 2015 03:57 PM
