Other side of this bolt?
Re: Other side of this bolt?
it's a stud in the heater box, not a bolt. If the nut is seized you have a problem
Car: 85 Trans AM
Engine: Chevy 355
Car: 89 Iroc Convertible
I always have trouble with that bolt whenever I try to remove a non a/c heater box from the junkyard cars.If that one doesnt come out I usually just give up
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: 85 Trans AM
Engine: Chevy 355
The nut on mine is seized and the whole stud spins.
I can take a picture of the replacement stud i plan on using.
Thanks for the replies so far.
Car: 85 Trans AM
Engine: Chevy 355
Here is the pis of the stud/bolt. It looks like it screws in plastic. I pulled this/and the heat/ac box out of a Camaro that already had the dash missing.
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
The replacement one you have shows the reverse torx end that makes it easy to remove a stuck nut. Try using a screw/bolt extractor on the stud end and a 10mm wrench on the nut. Soak it in PB Blaster for a day and keep spraying it. Should come off then.
Car: 1987 Trans Am
Engine: LQ9/L92
may be able to use some needle nose vice grips to hold onto the of the stud while you use a wrench on the nut. may not be pretty afterwards, but it may be just enough leverage to unstick the nut
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello jprix!!
Try using a dremel tool, with a cut off wheel, (and a little patience) and split the nut/captured washer!!
You said your going to replace it with another, so it doesn't have to look pretty, as long as you get it off!!!
Terrell351
Jun 13, 2021 01:13 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
