hatch pull down problem
Old Oct 21, 2010 | 09:30 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Im having some problem with my hatch pulldown, my pulldown moter is leaning away from the rear of the car and is leaning towards the front of the car, so when i go to shut my hatch i have to get into the back seat, reach acrossed the well area and push the moter back towards the rear end of the car and hit the glass or have someone push the hatch down so that its on the moter, if i dont the hatch doesnt latch because the moters leaning to far away, is there any way i can fix this? its getting old having to do this....
Old Oct 21, 2010 | 04:19 PM
Engine: L31 350
Re: hatch pull down problem
anyone?
Old Oct 21, 2010 | 04:23 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
are the bolts tight?
your guides might be worn...or non-existant.
http://www.top-downsolutions.com/ind...83a7f527673878
Old Oct 21, 2010 | 04:28 PM
Engine: L31 350
all the bolts are tight, the track that the moters on doesnt move, just the moter, i shouldnt say track more like mount
Old Oct 21, 2010 | 04:30 PM
Engine: L31 350
do i need these? http://www.top-downsolutions.com/pro...21a2f0eede6e13
and how do i replace them?
Old Oct 21, 2010 | 04:43 PM
eagle_eyes's Avatar
Engine: '93 LT1
the part that grabs the hatch moves up and down inside a track. there are 2 tracks in the assembly. the metal arms that are moving in the tracks should have 2 nylon guides each...one on each side. this is what holds the part sturdy. they can "dry" out and fall apart. check to see if you have them or not. if not, then wiggle it back and forth and see if that's where you have the play at in your motor unit.
Old Oct 21, 2010 | 04:49 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Yes, you need those the guides. That why there is so much play with the pull down motor. Try downloading the hatch instructions from TDS so you know what is involved with the installation. It is NOT rocket science to repair the hatch pull down.
Old Oct 21, 2010 | 05:11 PM
Engine: L31 350
im not seeing where they are at, can someone please show me a picture so i know where to look?
Old Oct 22, 2010 | 08:06 AM
eagle_eyes's Avatar
Engine: '93 LT1
http://www.top-downsolutions.com/Doc...structions.pdf
2nd page, 1st picture.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
Infested
May 22, 2018 11:56 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
madsv1000
Aug 20, 2015 06:45 AM
