1989 Firebird steering column compatibility
Old Oct 23, 2010 | 12:14 PM
AmorgetRS's Avatar
I know 89 was an odd year because it was basically the only year with VATS standard and no air bag. However, is there an actual difference in the columns that doesn't allow you to swap your VATS ignition and wiring into a older column? It seems to me GM would of used the same column and figures out how to make the VATS fit rather then go with basically a one-off design.
All my searches turn up a 89 is different because it has VATS, but there is nothing else listed as different and they always recommend grabbing the VATS box, too (meaning they don't expect you to swap the ignition).
Old Oct 23, 2010 | 12:20 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: 1989 Firebird steering column compatibility
You can replace it with any '82-'92 column the only difference I see is the wires running through it . If you get an early column then just run the ignition lock vats wire through it to the connector under the dash and your done . if you get a '90-'92 column pull all the air bag wiring out and your good to go .
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
