In need of advice for new stereo & speaker installation
Old Nov 10, 2010 | 09:01 AM
IROC 85's Avatar
Car: 1985 IROC-Z, Black and Grey
Engine: 305, TPI
Transmission: 700 R4
I have a 1985 IROC, and I am installing a new ALPINE stereo and speakers (front & back). No amp or sub, just head unit and speakers. I have the wiring harness and adaptor kit. The speakers were ordered same specs as original. I'm looking for any advice, instructions, feedback and (tips) to make this a smooth installation. Dash removal and return tips? Wiring tips? All tips and or advice will welcomed, Thank you all
85' IROC Z-28, black with grey interior, 18,000 original miles, original paint, engine, interior, nothing changed-swapped-cut-Aint she sweet
Old Nov 10, 2010 | 09:11 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: In need of advice for new stereo & speaker installation
Read the tech articles on this site. Years ago I wrote some step-by-step installation instructions for various components. Also, do a search on the car audio forum. Your installation is very common and something that's been done many, many times by members here, so there should be a lot of good info for you to sift through.
Everything is an easy drop-in on an 85 Camaro, with the possible exception of the dash speakers. Some stick up high enough to interfere with the underside of the dash pad, some don't. Hopefully the Alpines don't.
6x9s are a drop-in swap. The head unit is an easy replacement as long as you bought the mounting adapter kit. It looks like hell because it sticks a mile out of the dash, but it installs easily.
Old Nov 10, 2010 | 01:36 PM
IROC 85's Avatar
Engine: 305, TPI
Thank you sir, for your response. I'll check it out. I guess I put the cart in front of the horse without checking the audio section first. Thanks again
Old Nov 15, 2010 | 04:32 PM
Moe87's Avatar
post pics of everything you purchased when you get them. I can help with the wiring inside to the old system.
Old Nov 16, 2010 | 08:35 AM
IROC 85's Avatar
Engine: 305, TPI
I'm good on wiring..I think? Any tips on removing dash for front speaker swap? Thank you.
Old Nov 16, 2010 | 10:16 AM
Moe87's Avatar
that one is the easiest part.
Get a flashlight and look just under the lip of the dashboard. You will see 6 some bolts holding the underside down (cant remember what mm they are) and then look at where the defroster heat comes from on top, another 3-4 bolts there.
Remove all those bolts, put your steering wheel all the way down, lift up on the dash and just wiggle/pull it towards you. The foam can and will get torn and stuck on stuff, just be patient, wiggle it and she'll come out.
Keep the bolts on the passenger side floor for safe keeping, i lost mine 3 months ago and never rebolted my dash since
Old Nov 16, 2010 | 02:23 PM
IROC 85's Avatar
Engine: 305, TPI
Sounds easy enough, I think thats what I'm worried about. I read a few posts about removing the dash and it sounds too easy if you know what I mean? Thank you all for your help. I'll keep you posted
Old Nov 17, 2010 | 06:55 AM
IROC 85's Avatar
Engine: 305, TPI
Front speakers are in, lotta worries for nothing. Rear speakers didn't come with speakers connectors so I'll get them in tonight. Thanks for all the great advice, and I must admit, even though on numerous posts and threads people comment on not losing/ dropping any screws down the defrost because there gone forever. Well, even taking my time and acually holding the last screw...gone...forever! Thanks again-
69 Six Pack
Oct 5, 2015 07:51 PM
justin57
Aug 20, 2015 07:05 PM
Hello, Michael
Aug 20, 2015 03:19 PM
