lights switch removal
Old Jan 23, 2011 | 04:24 PM
camaro j's Avatar
Car: 1988 camaro
I HAVE A 88 CAMARO TRYING TO REPLACE THE DASH TRIM WERE THE LIGHT SWITCH IS BUT CANT FIGURE OUT HOW TO GET THE NOBE OFF WITHOUT BREAKING IT SOME ONE HAVE A SECRET TO GETTING IT OFF THANKS
Old Jan 23, 2011 | 04:32 PM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
Re: lights switch removal
take the plastic pice under the dash and reach up to the light switch there is a metal button you have to push and the *** and rod come out
Old Jan 28, 2011 | 01:25 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Turn the caps lock off tiger, thank you
There is actually a metal tab on the back of the ****. If you pull out the **** like turning on the headlights you can slip behind it and use a hook tool or something to push on the metal tab to relieve its grip on the metal rod (works like a friction jack or the metal tab on a caulking gun that makes the handle push the rod). While pushing, pull the black plastic **** off. Then the rod is still in the switch so you can turn your headlights off.
If you wear make up, take the mirror from you compact and you can use it to see the metal tab.
When you use the release button on the bottom of the switch when you remove the **** with the rod the headlights come on and stay on until you push the rod back in and it locks back into place.
Old Jan 28, 2011 | 10:12 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Originally Posted by Mad_IROC-Z
If you wear make up, take the mirror from you compact ......
Sorry - heterosexual 45yo male here - not that I disapprove of anyone's lifestyle preferences, and I totally get that the OP may in fact be a female, but ...
This just made my day!
I personally never had any luck trying to take the **** off the rod - I always just went under the bottom dash and pushed the metal button to remove the rod from the switch. Note that the metal button may be hard to see - there's a ton of wires there, and the metal usually rusts from humidity making it brown/and hard to spot. The button is also domed so it's hard to push - I use one of the screwdrivers that has the security star end, so that the security 'hole' in the end kinda hugs the dome and doesn't slip off. You have to push up on it hard.
http://www.sears.com/shc/s/p_10153_1...&blockType=G13
Old Jan 28, 2011 | 03:01 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
I wish homosexuals would stop feeling they have something to brag about and just keep their private lives in the bedroom like the rest of us!
But I was not asuming any sexual orienatations about the OP. Even a girlfriend or sister or mom could have one of those things. Thought it better than say "coke mirror".
If that clip is too hard to do then if I remember right you can also pull the **** out turning the lights on and unscrew the bezel and see the silver button under the switch through the holes behind the bezel as well.
And back in high school (over 26+ years ago) there was a hard rocker Iron Maiden/Ozzy type guy that would sit in his van before school started putting on some eye shadow or some stuff there. So the OP could also be a head banging rocker type
Old Jan 28, 2011 | 03:06 PM
Car: 1992 RS
Engine: Carbed 350
Yeah, I know - there's endless possibilities for the make up mirror - it just struck me as funny and was a highlight to my day!
Old Jan 28, 2011 | 03:46 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
I don't have a make up mirror but I do have the one I stick to my shoe for checking up skirts. I'm not a perv or anything. Just these days you need to make sure what a gal has up her skirt before you talk to her.
Old Jan 29, 2011 | 04:43 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Also, if the screw is too tight just use a vibrator to loosen things up.
Old Feb 10, 2011 | 07:25 PM
camaro j's Avatar
Car: 1988 camaro
thanks guys for the help i don't know what all the talk about the mirror and the homo crap was about but i just wanted to know how to get the *** of the switch thats all and iam a guy not a women and iam married with 3 kids so no homo here
Old Feb 11, 2011 | 06:26 AM
Car: 89 IROC
Sometimes we like to see the humour in things. No one says this board has to be serious all the time.
Glad you found a way to loosen up your "****". It's good to have a loose **** sometimes.
Old Feb 20, 2011 | 09:33 PM
diana227vegas's Avatar
Car: 1988 Convertible Iroc Camaro
I wish people on here were serious, because after all the sillyness I still can't figure out how to remove the light switch. Not just the **** ,the switch and all.It is very cramped in there,how do you access the switch?
Old Feb 20, 2011 | 11:55 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
You need to remove the panel under the steering wheel to be able to reach up and get a hold of it. When you remove the bezel in front of the switch and get either the **** or **** and shaft off you then have to unscrew the plastic nut holding the switch in . You get to it from the front using either a flat bladed screwdriver or needlenose to unscrew it. When loose you have to unplug it and pull out from the bottom or from the side if you want to remove the gauge cluster for access there. Kind of a pain but patience helps. Easiest if you get the shaft and **** out first
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
