i wanna throw the speedometer orr a cliff..
Old Jan 25, 2011 | 06:23 PM
walkthelin3's Avatar
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
i just got a 145 mph speedo for 80 bux to replace my 85 mph speedo.. 85 mph speedo came out semi easily but putting the 145 mph speedo is near impossible.. for some reason its not fitting in right.. its the same size and shape as the 85 mph one... its very hard... i cant even pry it in.. it appears as if its sitting higher then where it should be.. cant move it down to fit.. any suggestions?
Old Jan 25, 2011 | 10:35 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: i wanna throw the speedometer orr a cliff..
Lower the steering wheel all the way down and hold it down. Try to hold the cluster more towards the right side of the dash, and sort of "turn" it up and into the dash. If that doesnt work, lower the steering column slightly and it should fit in.
This is assuming the steering column is in the way?
Got pics?
Old Jan 25, 2011 | 10:39 PM
Axle/Gears: 3.47
yes the collumn was in the way.. got it now.. there were two bolts or so holding the steering collumn up.. tilting the collumn wasnt working...unbolted it and the collumn slid down enough to have it slide in like butter.. thank you!
Old Jan 25, 2011 | 10:44 PM
No problem, glad you got it figured out.
Old Jan 25, 2011 | 10:47 PM
Axle/Gears: 3.47
yeah.. now all i need to dois figure out why my engine just stopped getting fuel pressure... i dont get fuel at key... i just replaced the pump under warranty and the new pump isnt pumping anything... the relay isnt turning on and wheni manually activate the relay nothing happends... is there a fuse for the pump or is the relay the only thing?
Old Jan 25, 2011 | 10:58 PM
Not too sure on that one, just check all the fuses anyway. I think the ecm controls when the relay is activated to turn the pump on, but thats as much info as I can give.. Good luck solving it!
Old Jan 26, 2011 | 03:15 AM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
2 fuses, on on the passenger side frame rail by the battery tray, one in the fuse box
Old Jan 26, 2011 | 10:19 AM
Axle/Gears: 3.47
i dont recall seeing any fuses there.. any chance i can get a pic?
Old Jan 26, 2011 | 10:21 AM
Axle/Gears: 3.47
.under the hood fuses.. and i couldnt find one under the dash either...
are the under hood ones fusible links? or are they regular fuses
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
ndndndnd
Sep 28, 2015 08:00 AM
