85 camaro Rear Cargo Shade Install
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Hello all. I would like to know if anybody here either has or had a Rear Cargo Shade in the car and if so do you have photos of how it was mounted? I have one and I installed it but something doesnt seem right so I am not useing it at the moment but it is in the car. What I am talking about is were the round plastic end pieces go into the rear above the back seats. I have them in but I can seem to make them solid and not twist when I pull the shade. Any help would be great.
Guest
Posts: n/a
Re: 85 camaro Rear Cargo Shade Install
Post up a picture and i can tell you where it is wrong and not setup right. There should be to mounts right under the where the hatch lifts go into place to lift the hatch. there black you drop it in and twist it.
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
You have one of the items in the pic on each side?
They fit in a large hole in the plastic panel about 4 1/2 inches center to center of the hatch lift support bolt.
They go through the hole and screw into the sheet metal of the inner structure.
Then on the hatch there is a bracket that the shade hooks to but this does not sound like what you're having an issue with.
Guest
Posts: n/a
But still need a pic or we can't tell what's messed up about it.
Axle/Gears: Stock
I would like to see were I screw them in, would you have a photo
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
I don't recall if there was a short bracket or they just screwed to the steel panel behind it.
No, I don't have a pic and I'm not taking apart my car for one either.
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Axle/Gears: Stock
Axle/Gears: Stock
Now if you dont want to help thats fine,LOL because I can find the info.
I was hoping that there was somebody here that may had just did an install of one of these,and that it would be freash in the mind.
Car: 1989 Camaro RS--
Engine: MPFI
Hello everone, I was wondering if any one might know where I could get a new bracket for my cargo cover. I have all parts but the end peice that the cover pulls through is broke. It is the complete end that hooks into the body bracket. I hope i explained that ok...
Axle/Gears: Stock
https://www.thirdgen.org/forums/inte...ml#post4826312
Now as far as I know you can find the end caps on ebay, but if the ends on the shade itself are busted you may have to get a whole new shade.
Engine: MPFI
Thank you for answering my Q.. It is the end of the shade itself. But the piece had a cap with two screws that fit the piece on to shade. It should be a part that can be replaced.So If anyone might know where I could find this piece would be greatly appreciated! Thanks
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I am sorry for ripping on you. But I didnt ask you to take anything apart. So thats was not nessary to say you went going to. As you recall all I asked was were it screwed to to keep it from moving, I didnt ask you to do any more than share a photo IF you had one. I have it mounted and it does work. I just need to see what metal brace you were talking about because there isnt anything close to it. And even on cars that it didnt come on, the rear plastic were it mounts has a pattern that all that needs to be done is to cut it out, but there is nothing to screw the end caps on.
Also the "cups" are twisting when you pull the curtain out because of 2 things, the notches on the plastic panels are too large and or the "cups" are not screwed down to the bosy panel that SHOULD be there if equipt. But if the mounting plate is not there, then you will have to do what I did and install a metal strap.
There are steel brackets under the plastic panels, for the mount screws. Most cars have the brackets spot welded to the body, but some are just riveted. The best way to install the cover, is to get the brackets from the donor car. If they're riveted, drill the rivets, or use a cold chisel and a hammer to cut the rivets. If they're welded you'll either need a spot weld cutter or a chisel. Then use pop rivets to install on the project car.
I wanted to remove the plastic panels from the donor car that I found but everytime I called the owner, he wouldnt answer his phone. So I figured that he didnt want me on his property anymore. Its all good now though. Im done. I just need to figure out why the curtain doesnt retract.
So I made another thread just for that issue.
So I made another thread just for that issue. Joined: May 2009
Im sure you have seen my installation right. Well Im done and everything for me is a good to go.
hectre13
Dec 11, 2023 08:14 AM
