gauge swap??
Car: 1985 Trans Am
Engine: 1978 5.7L 350 V8
Transmission: 700 R4
Axle/Gears: 10 bolt with 3.73 gears
gauge swap??
have gauges from four cylinder that was in it. 80 mph speedo and huge fuel gauge. and lights to indicate oil brake and temp. 85 firebird. want a trans am dash with large rpm and speedo. help?? sorry if im confusing
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: gauge swap??
Two things you have to be sure of:
1. Has to be a mechanically driven speedo, all the f-bodies up to either 89 or 87 are, I think 89 but its been a while
2. Any tach not from a car that had a 4 banger will be inaccurate, so you either will have to find a 4 pot tach(good luck I haven't found a 6 cyl one yet...) or get an aftermarket tach
Also you will have to buy an oil pressure sending unit to swap out with the switch, same for coolant temperature switch, needs swapped to a sending unit, oh and getting it out and back in the first time is a pita, particularly disconnecting the speedo cable, to get it back in you will probably have to drop the steering column a little
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: gauge swap??
82-89 Camaros were equipped with mechanical speedos. Birds were mechanical 82-85 or so, though some base models may have had the mechanical in later years.
JamesC
JamesC
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: gauge swap??
usually lots of those for sale by thirdgen.org members at: https://www.thirdgen.org/forums/interior-parts-sale/
Car: 1985 Trans Am
Re: gauge swap??
it is an 85 and has mechanical speedo. now has 350 with 700 r4. i just want all echanical guages instead of those dumb idiot light i have no accurate readings. jusst a light that turns on or off
Car: 85' Firebird
Re: gauge swap??
I know exactly what you mean. you don't get a tach, temp gauge, etc., but you get a fuel gauge the size of ur HEAD! drives me crazy. I'd love do swap out the gauges at some point, post pics please, would love to see it finished!
Car: 1985 Trans Am
Re: gauge swap??
ya i sure will. i really want some gauges tho. unless i add an aftermarket tach i will never know rpms or redline. but i want it stock looking... conflicting
Car: 1988 sport coupe
Engine: 305 swap
Re: gauge swap??
are you looking for a set of gauges? ive got a panel from an 85 berlinetta which originally had the 2.8 with oil pressure, big tach, temp and big speedo. but the speedo only goes to 85.
Car: 85' Firebird
Re: gauge swap??
yea. thats my problem as well, im just not sure that aftermarket gauges would look good at all in our cars. but im gonna have to have a tach... i've looked into snaggin some out of a ta and a couple other things, but i honestly just have more important thing i have to work on first, she is in kinda rough shape... ill keep my eye out for swaps that have been done and information on them, keep us posted, really interested to see how it works out for ya.
Engine: 3.8, 3.4
Car: 1985 Trans Am
Re: gauge swap??
yes the whole set is exactly what i need!!! the big tach and sspeedo. im ok with 85 mph
Car: 1985 Trans Am
Re: gauge swap??
Engine: 3.8, 3.4
Car: 87 Camaro Z-28
Re: gauge swap??
Car: 1985 Trans Am
Ghettobird52
Jul 5, 2024 11:18 PM
