4th gen dash and more
Old May 10, 2011 | 08:58 PM
vjgillespie's Avatar
Car: !991 RS Camaro
Axle/Gears: 4.10 4th gen
Finally finishing up this dash and Hvac box swap from a 2001 camaro into my 1991 rs. I can see why most people just trim the stock vents to fit the 4th gen dash as this was a royal pain in the butt. Took about a week and a half working on it when I had the time after work, glad I did it now that its done but not sure I would do it again. Let me know what you think.
Attached Thumbnails 4th gen dash and more-imag0288.jpg   4th gen dash and more-imag0332.jpg   4th gen dash and more-imag0297.jpg
Old May 10, 2011 | 10:10 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: 4th gen dash and more
cool, you using the stock 3rd gen fuse panel or a 4th gen one?
Old May 11, 2011 | 06:15 AM
Car: !991 RS Camaro
All 4th gen wiring from headlights to taillights, hope to get started on that next and get the motor and tranny installed.
Old May 11, 2011 | 08:29 AM
RyanEricW's Avatar
Wow, what a project, man. I hope everything works out. Post details about what you did and any special modifications. =)
Old May 11, 2011 | 02:09 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
thats crazy, as in crazy awesome..
Old May 11, 2011 | 02:58 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Are the firewalls the same distance from the dash on both cars so you just have to cut the hole and install the mounting ring? Also is there more room next to the engine with this heater box? I have been thinking about trying that. It looks like it would help with my 3.4 DOHC swap.
Thanks Mike
Old May 11, 2011 | 08:26 PM
Car: !991 RS Camaro
The box fit between the firewall and the 4th gen dash perfect and yes as far as the firewall part all i did was put the 4th gen mounting ring as far to the passenger side and down as it would go. The hard part was rebuilding the cowl area where the water drains from the wiper area out the passenger fender. I closed off the fresh air intake area (figered I could use the power windows for that haha) and put a hole in the lower cowl firewall area for the water to drain. First time I've been this far into a car before someone with a little better fab skills could probably keep it closer to factory.
Old May 11, 2011 | 08:38 PM
Car: !991 RS Camaro
Heres a couple more pics.
Attached Thumbnails 4th gen dash and more-imag0327.jpg   4th gen dash and more-imag0331.jpg   4th gen dash and more-imag0328.jpg
Old Jun 1, 2014 | 01:25 PM
Mr Pain's Avatar
Car: 91 camaro rs
Engine: 355 sbc
Transmission: muncie m22
Axle/Gears: 10 bolt limited slip 373's
Cant wait to start on mine. My 3rd gen doesn't have the stock blower or hvac so thats why I leaned into doing this. Having a complete donor car has lots of advantages.
Old Jun 1, 2014 | 01:26 PM
Mr Pain's Avatar
Car: 91 camaro rs
Engine: 355 sbc
Same here!!
Old Jul 7, 2014 | 12:26 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Would definitely like more info on how to do this. Meant to hit this thread.
Casey Meyers
Mar 2, 2016 10:46 AM
cam-mike
Aug 24, 2015 07:23 AM
