Interior Hatch Trim Screws
Old May 21, 2011 | 09:14 PM
fadedirocz28's Avatar
Car: 1985 Camaro Iroc-Z
Engine: LB9
Some of the screws and i guess you would call them retainers or nuts? broke in the hatch, They go in the side hatch trim, big plastic screws that go through the trim then the plastic piece that i guess inserts into the metal behind it that the screw threads into.
Does anyone know where i can buy some of these? or know of an easy solution? These interior pieces hanging off are on my last nerve.
i need both the screw and the other piece
Old May 21, 2011 | 09:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Interior Hatch Trim Screws
http://cgi.ebay.com/ebaymotors/82-92...Q5fAccessories
paint/dye to match, or look for the right color
Old May 21, 2011 | 10:31 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Note that you can buy them at your local big box parts store in the Dorman/HELP parts section. They also may have the "clips" that fit into the body that the plastic screw grips into.
These clips are now discontinued so check the above e-bay seller
Florida Auto Fasteners as they DO sell them.
Old May 22, 2011 | 08:32 AM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Check the classified section of TGO. I bought some tan screws (hard to find). I also repaired some broken ones by drilling a hole in them and screwing them together.
Old May 22, 2011 | 09:31 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You can buy these at Florida Auto Fasteners and they are called "interior cargo panel nut-clips". Package of (6) $5.00 and they are the same as the originals. They should also have the oversized plastic screws for them.
Old May 22, 2011 | 01:56 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
What color are you looking for ? I've got a bunch in different colors I'll give you a good deal on. How many of each do you want. PM or email me your email address if you want pics or other info, Henry
Old May 22, 2011 | 05:55 PM
Engine: LB9
I'm needing tan screws with the fasteners. I know of 2 that are broke but I'm sure once i get back there and start going over it there may be more, So I'm thinking 4-5 is how many i need. I'll probably just get the nuts from florida auto fasteners, and see if i put the screws up anywhere. No sense in you going through the trouble of shipping for such a small item.
Old May 22, 2011 | 06:47 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Sounds like a good idea. I only found two screws in brown anyways. Got tons of black and gray though.
Old Jul 5, 2011 | 10:20 AM
scottbons6504's Avatar
Engine: Stock 350
Transmission: 5 spd
Henryd3: how much for 12 shipped to 61032 in black?
Old Jul 5, 2011 | 12:12 PM
cmm7v3's Avatar
Car: 92 Camaro RS
Engine: 1JZ-GTE
Transmission: R154
i could also use a full set in gray if selling
Old Jul 5, 2011 | 12:27 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
For those who need black. Auto Zone sells in three packs. Clips and screw
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
lee01
Apr 9, 2016 01:56 PM
