tachometer bouncing
Old May 29, 2011 | 11:40 AM
G's82z-28's Avatar
Car: 82 Camaro Z-28
Engine: 350 SB bore 30 over
Transmission: Turbo 350
Axle/Gears: 3.77
tachometer bouncing
hi well ill get right to my problem i have a 82 camaro z-28 with a 350 and my tachometer starts to bounce my when i put my left or right blinker on i dont really know where to start any help would be awesome.
Old May 29, 2011 | 12:02 PM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Re: tachometer bouncing
I have the same problem. It started after my alternator was thoroughly soaked one day. I figured my regulator was on it's way out but just lived with it. 18 months went by and I eventually changed the alternator but the problem still exists. So I guess that was a coinsidence. I'm wondering now if the Alt simply isn't outputing full current at idle. It would be simple enough to prove - never seem to get around it.
Does your tach needle bounce during lane changes as well (higher RPM) or only when idling at a light?
Old May 29, 2011 | 12:07 PM
G's82z-28's Avatar
Car: 82 Camaro Z-28
Axle/Gears: 3.77
yeah it does the same thing when changing lanes too.
Old May 31, 2011 | 02:51 AM
thumperz's Avatar
put a volt ohm meter(digital voltmeter) on the battery and start pulling fuses,when the volts drop,thats the circut thats giving you probems. have fun.
Old May 31, 2011 | 12:06 PM
G's82z-28's Avatar
Car: 82 Camaro Z-28
Axle/Gears: 3.77
ok ill give that a try
Old Jun 1, 2011 | 08:13 AM
Car: '83 Berlinetta
Engine: 383 CI
I was having a problem with the battery discharging at one point. I did what ThumperZ suggested and it turned out that my alarm was causing the problem. I pulled the fuses out of the alarm module and it solved the problem. Do you have any aftermarket alarm or remote starter or anything?
Jon
Old Jun 1, 2011 | 12:57 PM
G's82z-28's Avatar
Car: 82 Camaro Z-28
Axle/Gears: 3.77
no i dont have anything like that no alarms or remote starters but i was looking under my dash at some of the wires and some of the splicing jobs that were done seem preety bad and not even covered just bear sire showing so could that be a part of the problem??
Old Jun 2, 2011 | 11:45 AM
Car: '83 Berlinetta
Engine: 383 CI
Bare wires for sure are a no-no. But do what Thumperz suggested to work out what circuit is causing the problem.
Jon
Nighthawkf-117
Sep 24, 2015 02:47 PM
buckeyecelt
Sep 24, 2015 05:50 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
