How to add mileage after a gauge replacement?
Old Jun 15, 2011 | 09:29 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
91 TA, analog gauges, 700R4 transmission
I recently swapped out my whole dash cluster panel because the Odometer had stopped working (easier than just doing the 1 gauge) but the new odometer shows less miles on it.
I don't want it to be showing wrong & am proud of my 230,000 miles, so I want to roll the new forward to read right.
If I understand it right, it is cable driven up to the dash, converted into an electronic signal, then the electronics spin the odometer. There was obviously not a cable connected to the back of the gauge.
Can I just pull the cable off the tranny, chuck it in my drill & spin it until the miles are added?
Old Jun 15, 2011 | 11:19 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How to add mileage after a gauge replacement?
It's all electronic, no cables anywhere.
Old Jun 15, 2011 | 11:46 AM
Car: GTA
Doesn't jive with what the FSM shows, but OK.
Basic question still stands. Adding mileage on an odometer after swapping gauges?
Old Jun 15, 2011 | 12:14 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Were it a speedo run by a cable, you just take a piece of cable, plug it in to the end of a drill, then the end of the gauge and spin it for oh...hours until you get the desired mileage. No idea on an electronic speedo. Probably the same principle though, just take out the box that converts the signal to electronic pulses or so?
Old Jun 15, 2011 | 12:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The problem with using a drill is that it takes 1000 turns of the cable (or the VSS gear) to register a mile. If your drill turns 2000 RPM, then you can put on 2 miles every minute. If your drill hasn't burned out after an hour of continuous operation, you'll only have added 120 miles.
Old Jun 15, 2011 | 12:32 PM
Car: GTA
OK
Any solution other than disassembling the Odometer & manually turning the #s?
Old Jun 15, 2011 | 12:51 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I never said it was a "good" idea. lol
Old Jun 15, 2011 | 06:09 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Why not leave it alone?
Old Jun 15, 2011 | 06:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
your odo probably stopped working because the little motor that turns the gears died. if you take the gauges back out, you can disassemble the gauge and should be able to swap the counter to the new pod using the new motor.
Old Jun 15, 2011 | 06:53 PM
Car: GTA
Just because I'm me & proud of my 230,000 miles.
Nope. The little plastic gears cracked & broke. Oh yeah, that was the Tripmeter, but still the reason I replaced the cluster & got a 145mph gauge out of doing it.
Next stop is white faces!
Old Jun 16, 2011 | 01:41 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
The first repair/inspection/emissions record on the Carfax after the new odometer will throw a big red flag on the car for 'inconsistent odometer reading'. Not exactly a selling point for most people.
Old Jun 16, 2011 | 02:42 PM
Car: GTA
#1-No emissions here
#2-Carfax is such a joke anyways. I've seen reports with accidents that never happened as well as wrecks that did happen, covered by insurance, yet not show up.
#3-I replaced it the first time over 3 years ago & "dropped" 50,000 miles. Just replaced it again & dropped another 20,000 miles. So any Carfax would already show a sudden drop in miles. Even the annual State Inspection already shows that.
Despite doing my state inspection yearly? No red flags have come up & is easily explained. Besides, I have no plans to sell it & I don't care so it won't matter anyways. And I don't want to REMOVE miles, getting it to show lower than it really is. I want to ADD miles for it to show more accurately.
Old Jul 19, 2023 | 05:23 PM
kema27's Avatar
With a drill it will be a headache get a square house fan take the protective plastic mesh off put something that will fit in you speedometer to make it turn I used the cap leg of a sharpie marker I super glued it standing up right in the middle of the fan then I placed the speedometer in top of the plastic mesh and inserted the sharpie cap leg into the speedometer I ducked taped it on the sides to secure shaking then I laid the fan facing up with a breathable pedestal (some pieces or house brick) and turned the fan on it makes my speedometer go about 30 mph in one whole day of letting it run at home it has put about 450 miles I need 21k miles so I got a ways to go
Old Jul 19, 2023 | 06:32 PM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
If the odometer works and the mileage is just off, you can remove the odometer from the gauge cluster, and with 2 jewelers flat tip screwdrivers pry up on the little retaining bar on the back side of the odometer, and with the other screwdriver gently rotate the digits.
i did the exact same thing on my 91 TA to make a mileage correction the PO didnt do after changing the cluster.
Old Jul 20, 2023 | 05:33 PM
NoEmissions84TA's Avatar
Charged350
Apr 9, 2009 10:53 AM
zmasta101
May 29, 2008 03:25 PM
razormedic911
Mar 6, 2007 05:39 AM
anjel
Jan 11, 2004 08:18 PM
TomP
Jan 15, 2002 09:42 AM
