NRG Quick Release Steering Kit...usable on third gens somehow?
Old Jun 21, 2011 | 12:40 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
been reading up on it and was wondering if anyone knew if they could work with our setups?
from what im reading...i need a hub, quick release, and steering wheel.
what hub would fit the quick release or does it fit the stock one? anyone know?
looking at this quick release and this wheel:
release
http://www.raceinspired.com/p-14858-...iliateid=10065
wheel
http://www.amazon.com/NRG-Universal-.../dp/B001BC0UCE
but im stuck on the hub part...
saw this video as well but its installing on a 240 but id imagine its quite similar to installing it on a third gen right?
http://www.youtube.com/watch?v=FDU3MoxMzYM
Old Jun 21, 2011 | 08:05 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: NRG Quick Release Steering Kit...usable on third gens somehow?
anyone?
Old Jun 21, 2011 | 08:27 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
grant SFI quick release GM hub and competition steering wheel
Old Jun 21, 2011 | 08:49 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
got any more info on the install?? looks really good!
Old Jun 22, 2011 | 09:41 AM
xpndbl3's Avatar
Car: 1984 Z28
remove stock steering wheel, install grant piece, install grant steering wheel
Old Jun 22, 2011 | 07:18 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
ah,,,,
which GM hub is it??
Old Jun 23, 2011 | 06:50 AM
Project-RS's Avatar
i have the same grant kit. very easy to install.
Old Jun 23, 2011 | 11:03 AM
xpndbl3's Avatar
Car: 1984 Z28
i'm not using that grant theft kit, mine is the SFI hub for racing purposes.
which GM hub...? there is only one for 5 bolt hole steering wheels from grant, kinda hard to screw it up
Old Jun 23, 2011 | 05:17 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
so would that 5 bolt hole GM hub be usable with the 5 bolt NRG quick release?
Old Jun 23, 2011 | 10:01 PM
xpndbl3's Avatar
Car: 1984 Z28
no the NRG will not bolt to your stock steering column, you need the GM grant quick release hub, that NRG looks like a ***** site.
grant wheels bolt to grant hubs, you need to buy a 5 bolt stering wheel to screw into the 5 bolt hub.
Old Aug 16, 2011 | 12:38 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
indeed it will..just got the email back from NRG..
Mikey,
Yes, those are the parts that you will need for your Pontiac Trans Am. Contact my vendor Martin of ACME 2 Motorsports to place your order. Mention to him that Mike from NRG referred you for the best discounts and pricing. 702-739-7373. His operating hours are from M-Sat 1100am to 700pm PST.
parts needed:
Hub:
http://new.getnrg.com/products/quick...t-hub/srk-170h
Quick Release:
http://new.getnrg.com/products/quick...-2.5/srk-250bc
Wheel:
http://new.getnrg.com/products/steer...-style/st-012s
yee
Old Aug 16, 2011 | 11:01 AM
firbster's Avatar
Car: 84 Z28,03 GSXR1000,07 RMZ 250
Engine: H.O. L69
Transmission: 5spd
Axle/Gears: 3.73 possie
i have the NRG kit installed on my car ,, it is an wicked kit.. extremely well made, retains the horn..
Old Aug 16, 2011 | 11:24 AM
firbster's Avatar
Engine: H.O. L69
Transmission: 5spd
Old Aug 16, 2011 | 11:25 AM
firbster's Avatar
Engine: H.O. L69
Transmission: 5spd
Old Aug 17, 2011 | 01:28 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
Nice dude!! cant wait to get mine
Old Aug 17, 2011 | 02:07 AM
87350IROC's Avatar
Car: 87' IROC
NRG makes excellent stuff. You will be happy.
Old Aug 17, 2011 | 02:37 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
awesome..good to hear
Old Dec 25, 2011 | 08:27 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
got it for xmas :P will be putting it on tonight when i can get a puller from autozone..gonna go at midnight haha
Old Jan 1, 2012 | 08:24 PM
firbster's Avatar
Engine: H.O. L69
Transmission: 5spd
so how did the install go ,, you happy with it??
Old Jan 1, 2012 | 11:28 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
very happy with it..havent had a chance to take pics..will tomorrow
Old Mar 20, 2012 | 10:59 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I'm still interested in seeing some pictures. Were your NRG pieces a direct bolt on?
Old Mar 20, 2012 | 01:24 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Im running the samething as project-rs
Old Mar 20, 2012 | 09:18 PM
Tibo's Avatar
Car: 1991 Z28 Vert
What year was that installed on? Any modification of the column or the kit necessary?
Old Mar 21, 2012 | 03:27 AM
6SIX6's Avatar
Car: 89 IROC
its on a stock 82 to 89 tilt column and there was no modding at all that I did. actually i had to make the horn button work is all took 2 min and 10min to get the quick release on
Old Mar 21, 2012 | 10:50 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Sounds promising. My worry is that it is different after 89 as there might have been a change made when the airbag came around as this thread suggests: https://www.thirdgen.org/forums/inte...eel-grant.html
Old Mar 21, 2012 | 01:20 PM
6SIX6's Avatar
Car: 89 IROC
Columns are the same it just has a wire for the airbag. If your not running the bag and dont care cut the wire off or tuck it into the column somewhere. Everything else is the same. oh and pull the airbag light or it will be on all the time
Old Mar 23, 2012 | 11:08 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
that ^ and inless you want to do some extra thinking, you wont have a horn
ill get pics tomorrow since ill have time
Old Mar 24, 2012 | 08:31 AM
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
'Got any postable pics yet? I just stumbled onto this thread. Loving the looks and idea of the NRG wheels and quick release.
M
Old Mar 24, 2012 | 08:58 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Can someone explain what the quick release does?
Old Mar 24, 2012 | 09:49 AM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Enables the steering wheel to be removed quickly.
Old Mar 24, 2012 | 09:52 AM
92 BBC Z's Avatar
Does NRG make any that are SFI?
Old Mar 24, 2012 | 11:16 AM
Tibo's Avatar
Car: 1991 Z28 Vert
like the other member mentioned, it just pops off quick and easy. It is great for/if you do much dash and wiring work. Its also a great theft deterent. I do some car shows and auto cross events as well as driving the car leisurely around town, just gives me piece of mind.
Old Mar 24, 2012 | 01:23 PM
92 BBC Z's Avatar
My bad. I thought he meant 'function' when I read " what it does". It provides a way to remove the wheel quickly for ease of entry/exit when a roll cage or fixed seat is used.
Old Mar 25, 2012 | 07:59 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
its just easier to get out of the car with the roll bar and it looks cool..also a theft deterrent..
sorry guys..its been raining -___- sunny cali right?
Old Mar 29, 2012 | 11:58 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
finally..installed pics
Old Mar 30, 2012 | 12:57 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Holy Moly! Sure glad I saw that side view pic before purchasing one. It really appears to move the steering wheel forward. Can you still use the turn signal lever with your hand on the wheel still? The Grant setup doesn't appear to move the wheel out nearly as much.
Old Apr 1, 2012 | 01:34 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
nope..gotta take my hand off..it does move the wheel closer..the hub pushes it closer to the driver but for me it didnt really change much..only like 2 maybe 3 inches
Old Apr 1, 2012 | 02:44 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Even without the roll cage is it still a bit easier to squeeze into the car? I'm 6'1" and got some pretty long legs and my knees barely fit under the steering wheel to get in lol.
Old Apr 1, 2012 | 02:48 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
makes getting in and out easier in any car so yes..haha
Old Apr 1, 2012 | 11:49 AM
87350IROC's Avatar
Car: 87' IROC
2-3" is huge. That totally changes the way the car fits you.
NRG offers a slim disconnect and you can combine that with a flat steering wheel instead of the high offset wheel that itsMikey has chosen and the difference would be minimal.
Old Apr 1, 2012 | 11:55 AM
Dakota W.'s Avatar
Just looked at the price for the grants...200 bucks AND a new steering wheel, my wallet is on a diet right now unfortunately...
Old Apr 3, 2012 | 02:06 AM
  #42
Kidfromthe951's Avatar
Car: 91 Camaro RS
Dang looks like I'm adding this to my to do list, looks good will be going with this wheel http://www.amazon.com/NRG-Steering-W.../dp/B005KFOTN4 with a white bowtie button.
Old Apr 3, 2012 | 02:07 AM
  #43
itsMikey's Avatar
Engine: 5.7 350 TPI
mine is the slim but yeah i got a deeper wheel..the wheel alone has a 2" outward push..so it probably only moves it maybe an inch or so with a flat..
its probably less than im estimating but it didnt really change the way the car feels in the way youre implying but it did give me the feel that i have more control over the car as this wheel is a tad smaller..
Old Apr 4, 2012 | 07:11 PM
  #44
LivinLarge's Avatar
Did u get the hub from the link in your first post? And do you have to use an NRG wheel with this?
Old Apr 4, 2012 | 11:50 PM
  #45
itsMikey's Avatar
Engine: 5.7 350 TPI
you can get it a lot of placed but yes
and no, you can get any 6 bolt wheel (momo, sparco etc) NRG's stuff is cheap and good quality tho so why not? Nardi was my first choice but $200 for a wheel? nah
Old Apr 5, 2015 | 11:20 AM
  #46
87_teetop's Avatar
does anybody still use this page?
Old Aug 16, 2015 | 07:01 PM
  #47
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Bringing this thread back from the dead. yeah I know. I know but those links don't work anymore. Do you have part numbers on which quick release hub works ect.
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
neekolzun
Aug 24, 2015 04:59 PM
smooth
Aug 18, 2015 06:34 PM
