Cup holders
Old Jul 10, 2011 | 07:53 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Cup holders
Another member here "UNCLE TOM" and also a member of our local 3rd. Gen car club ask me to post up his custom cup holders he made from a modified holder available at you local car parts store. The original version can be seen on the floorboard.
Old Jul 10, 2011 | 08:33 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Cup holders
thanks david for the post & pics. . this is the best set-up i could think up with no hacks , holes in anything . just use of existing screws . i am very happy with my set-up . if you look at original part it was fabricated from , i put masking tape on it to show what/where to cut away . the front mount is the stock console screw . the rear is also stock console screw with a short tab to secure . cost $7.50 for wedgie cup holder , fine hacksaw blade , sandpaper to smooth edges , small 1/8" drill bit , one of the cheapest & best mods. i have done to my car . looks almost factory , function perfect . who said an OLD DAWG can't come up with new tricks . cheers !!!
Old Jul 14, 2011 | 07:48 PM
UNCLE TOM's Avatar
Re: Cup holders
wow 80+ views and no comment ? easy , cheap , no hacking of console and fully functional . i thought maybe one person would have a comment . oh well , cheers !!!
Old Jul 14, 2011 | 09:28 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Cup holders
i like it but it looks like it robs the passenger of the leg room over there?
Old Jul 14, 2011 | 09:49 PM
UNCLE TOM's Avatar
Re: Cup holders
i have had no complaints , only compliments . from 6'2" to 4'11" adult passengers . oh well , mine stay . they do not hinder passenger room or drivers room (they are on both sides) thanks , cheers !!!
Old Jul 23, 2011 | 04:48 AM
AKcamaroAK's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 350 V8 4bbl
Transmission: Automatic 700r4
Axle/Gears: 2.73 Open Diff
Re: Cup holders
Really great idea Tom! I've had those wedgie holders in my car for months and i've never thought of this. One question though, what did you use on the back screw hole? it looks as though you bridged it with something so it would reach the factory screw hole.
Old Jul 23, 2011 | 07:02 AM
UNCLE TOM's Avatar
Re: Cup holders
thanks , i actually used a metal hose clamp . straightened it , cut it in half , drilled a small hole , done . good luck .
Old Jul 24, 2011 | 12:44 AM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
Re: Cup holders
Looks like it works pretty good. I have the same cup holder and it gets in the way when i have a passenger. Might have to look into doing this as well.
Thanks for the idea.
Old Jul 30, 2011 | 01:53 PM
bedbed's Avatar
Car: '82 Z28
Engine: 305 LG4
Transmission: 200c
Re: Cup holders
I was using the wedgie between the seat and console for a few years so decided to try this also. Here is my mock-up of the modified wedgie. Used 1/2" all purpose strapping with screws/nuts/washers to hang the holders, again by the console screws. Shot the viewable strap and screw with tremclad semi-gloss. Are sitting in font of the console vents but it is 90+ degrees and car does not have air. That travel mug is 20oz and is in a very comfortable position that leaves the gear selector, radio and vent/heat controls unblocked. Do have a new wedgie ready to cut and will do more work on the cut edges of that.
bedbed
Attached Thumbnails Cup holders-pict0006.jpg   Cup holders-pict0003.jpg   Cup holders-pict0001_00.jpg
Old Oct 14, 2011 | 02:12 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Cup holders
Wow i really like this idea how exactly is it holding did u screw it into the cinsole or is it just some kind of double sided tape. I wanna do this to mine since that's the main thing I hate having to hold my drink while driving.
Old Oct 15, 2011 | 11:36 AM
bedbed's Avatar
Car: '82 Z28
Engine: 305 LG4
Transmission: 200c
Re: Cup holders
I am using the front console plate scew to hang the holder. Cut/trim your wedgie; cut length of strapping; drill holes in holder through holes in strap; screw holder to strap; stick foam tape to strap to protect vent/keep from rattling; paint exposed strap and screw; install in said location. Works great. Next thing is where to put loose change etc now that we have removed centre part of wedgie.
Attached Thumbnails Cup holders-pict0006.jpg   Cup holders-pict0007.jpg   Cup holders-pict0009.jpg
Old Oct 15, 2011 | 04:01 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
Re: Cup holders
I used the left over plastic to make my brackets. It doesnt look the greatest but works very well.
Attached Thumbnails Cup holders-100_1369-medium-.jpg   Cup holders-100_1371-medium-.jpg
Old Oct 15, 2011 | 07:01 PM
UNCLE TOM's Avatar
Re: Cup holders
ck. the top 2 pics again . with the handle opening towards seats you can get a tighter fit . i cut up 3 sets before i was happy . good luck .
Old Oct 15, 2011 | 10:03 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
Re: Cup holders
Your right it does look like a cleaner fit. I think when i first saw your post I was in a hurry to try it out. Its a cheap cup holder so like you said I will have to try another one. Thanks for the idea.
Sean
Old Oct 17, 2011 | 08:47 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Re: Cup holders
I've done quite well w/o cup holders since 1986, I don't drink in my car so I don't need them, but thanks for the 411 anyway.
Fanatic1074
Oct 3, 2022 05:57 AM
75bike
Sep 20, 2015 09:37 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
gta892000
Sep 16, 2015 12:37 AM
