will 4th gen seats fit in 3rd gen "iroc body"
Old Aug 31, 2011 | 08:59 PM
IROC925's Avatar
i mean i know they can FIT but will they correctly bolt up with out modifying???? or is the 82 - 92 bolt pattern same with 93-02??? 82-02??? because i see so many people with this conversion done and i would like to do this as well
Old Aug 31, 2011 | 09:05 PM
aqualordx93's Avatar
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
Re: will 4th gen seats fit in 3rd gen "iroc body"
Yes they bolt right up. Just finished putting mine in the other day, Best modification so far.
No Modifying necessary.
i own 86 IROC, and i have 98-02 camaro Seats in now.
Old Aug 31, 2011 | 09:09 PM
IROC925's Avatar
so i wont need to swap the brackets over or anything like that???? and what about the rear seats they bolt and fit in perfectly as well
Old Aug 31, 2011 | 09:14 PM
Engine: V8 305 TPI
If the 4th gen seats come with the brackets (seat rails) on them (which mine did) they bolt right on (usually the seat rails are on).
Honestly, all i did was put it in the car, lift it up, and plop it down and all of them lined up, put the bolts and it works fine.
Rear seats are bolt up as well, although on mine i have noticed that if you push on a seat on the far left or right it kinda bends funny, but it is not a problem for me.
Old Aug 31, 2011 | 09:19 PM
Engine: V8 305 TPI
These are the Rear seats in, and the front seats out (they are now in just dont have a picture)
Attached Thumbnails will 4th gen seats fit in 3rd gen "iroc body"-img_0923.jpg   will 4th gen seats fit in 3rd gen "iroc body"-223551_10150165371953432_698728431_6755174_2734820_n.jpg
Old Aug 31, 2011 | 11:10 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
If your 3rd gen currently has the power seat track, you can remove it from the current seat and it will bolt perfectly onto the 4th gen seat.
Old Sep 1, 2011 | 01:07 AM
cookie21's Avatar
Car: 1992 RS
Engine: ZZ4
looks like a very nice interior aqualordx93.
Old Sep 1, 2011 | 09:11 AM
IROC925's Avatar
actually the current seats i have now are not electrical so im pretty sure it wont have the connections either for electrical seats to work for it either i wont know till i take them out and i doubt it pretty much sounds like im gonna have to transfer my seat rails over....
Old Sep 1, 2011 | 09:24 AM
mikesanto70's Avatar
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
If you would like to keep the new seat power, just wire it directly to the fusebox and make sure to a fuse in the link/wire to box, so you dont burn your car down!!!
Old Sep 1, 2011 | 09:26 AM
Engine: L99 L98
Or tap into the wires in the kickpanel, just use a test light to find a hot wire and tap into it, Walla!!! Power seat!!!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
