What interior light is this?
Old Nov 27, 2011 | 11:46 AM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
I have a 1991 camaro and since i bought a new radio i decided to install it. After some time i realized there was a little circular light above the A/C, and under the center vents. It turns on when i put my headlights on but its very dim, so i removed it and when pulling it out there was a connector that had to be unplugged. I searched everywhere and couldnt find an answer of what its for or the replacement bulb for it (if it can even be replaced). Anyone know??? Dont have any pictures because my cars in the shop, thanks.
Old Nov 27, 2011 | 11:54 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: What interior light is this?
search for map light. its pretty much a useless light.
Old Nov 27, 2011 | 12:00 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Can the light bulb be replaced? Or is it a one time deal bulb built in?
Old Nov 27, 2011 | 12:10 PM
travis401's Avatar
Car: 91 Camaro RS
im sure it can be replaced, just dunno what the bulb size is.
Old Nov 27, 2011 | 12:17 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Thanks, so im guessing the cars that didnt get a map light above by the rear view mirror got one down there?
Old Nov 27, 2011 | 12:19 PM
travis401's Avatar
Car: 91 Camaro RS
mines got the map light on the mirror and the small light on the bottom of the dash.
Old Nov 27, 2011 | 12:32 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I've heard it called an ash tray light which makes sense to me because it is so dim.
https://www.thirdgen.org/forums/inte...ray-light.html
Old Nov 27, 2011 | 12:55 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Thank you! Thats exactly what i needed
Old Nov 27, 2011 | 02:06 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
yep its a ashtray light, check out my LED conversion on it
https://www.thirdgen.org/forums/elec...-controls.html
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
