Mirror with map lights question
Old Dec 22, 2011 | 07:01 PM
travisgold's Avatar
Car: 1984 Camaro Z28
How hard would it be to wire up a mirror with map lights in a 88 firebird?
http://www.hawksthirdgenparts.com/ca...maplights.aspx
Step by step would be nice, im just trying on making my car really nice and sweet, some info about the car it has t tops, its a base, 2.8l
Old Dec 22, 2011 | 07:30 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Mirror with map lights question
I would imagine that it would be connected to the dome light with some sort of plug,or just ruffed in with it.
Old Dec 28, 2011 | 03:27 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
If you have the factory harness its plug and play man. I put one on my 89 and it was super easy to do. only mod you have to do is maybe change the connector where it ties into the factory harness. If you dont have the harness it wont be as easy as you would need to make all the connectors for the dome light and then the map lights. I might have a mirrior and harness if you need one
Old Dec 29, 2011 | 12:03 AM
travisgold's Avatar
damn it now i really wish i would of got that mirror from the S10 in pick n pull its the identical mirror they use in the thirdgens and it had the wiring harness, does it plug straight into the fuse box under dash?
Old Dec 29, 2011 | 04:49 AM
6SIX6's Avatar
Car: 89 IROC
I took a pic of the plug last night from my car as I was doing some dash wiring. Here is the connector you are looking for. You might have to cut the S10 or camaro one off the mirrior side of the harness and reattach the one in your car now. Thats what I had to do as the interior harness piece is different but its easy to wir together and will take a minute to do.
Its the one my finger is pointing to with the white and orange wire from it.
Old Dec 29, 2011 | 12:42 PM
travisgold's Avatar
Hmm i see, the S10 was a brown wire connecting to the mirror so im guessing i will just try to find a wiring harness similar to that? In the local pick n pull yard there is one thirdgen with the overhead console and map lights so i will just grab the wiring harness from there also im going to grab its iroc hood haha
Old Dec 31, 2011 | 03:50 AM
6SIX6's Avatar
Car: 89 IROC
as long as it has the map lights in the mirriors it will work. Let us know if you get it
Old Dec 31, 2011 | 05:23 AM
travisgold's Avatar
Haha okay I will forsure, I might not be able to get it for a bit since I have to do a few things to work on my car, its been running pretty rough lately, I took it out yesterday and I did something pretty stupid, I went 80km down my street and the limit is 50km, the funny part is that i made it from 0 - 80 in 5 seconds which is pretty good for a 2.8l and a guy that really doesn't know how to drive standard, I drove damn good didn't stall once, or burn the clutch!
Old Dec 31, 2011 | 11:24 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
being my 86 S-10 is as base as they come (manual EVERYTHING) it didnt have any sort of int light so i snatched the small amount of harness, drilled a hole above the mirror in the frame around the front glass for ground and found a constant hot in the fuse block. works like a champ.
i plan on doing this in my sons 83 T/A as its a nice convienience. my 89 came factory. get a harness from a car that dosent have the extra lights in the dome.
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
89FormulaMan
Aug 10, 2015 10:01 PM
Omega
Aug 10, 2015 12:46 PM
