4thGen Console Lid,Trac.Control plate,and Shifter boot fix help
Old Jan 4, 2012 | 06:27 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Bought a console off a guy on here that needs work. I think the lid just needs hinges but i havent really looked at it much. The shifter boot needs to be replaced,and the plate is missing from where the Traction control button was. Also,the top console just slides right off. Help would be greatly appreciated. Im putting my power window switch where the Trac plate goes
Old Jan 20, 2012 | 01:37 AM
Re: 4thGen Console Lid,Trac.Control plate,and Shifter boot fix help
Bump
Old Jan 20, 2012 | 07:06 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
it also looks like you're missing the trim piece around the shifter boot. should be able to grab it off ebay though
Old Jan 20, 2012 | 11:07 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
That metal thing inside the shift boot IS a replacement shift boot ring from an aftermarket source (supposed to be better than the stock plastic ring that breaks every time you look at it). Looks like it's damaged and needs to be bent back into shape.
OP, not sure on the armrest (as I don't have one), but you need to salvage a couple long screws from your old console to hold the shift plate in. They go into the 2 holes that are in the compartment under the armrest. As for the TCS/2nd gear start plate, you don't need it. You can get a handy little compartment off of eBay or somewhere that fits into there (it's a factory piece and that's what it's designed for), or you can get the switch plate.
Old Jan 20, 2012 | 11:16 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
blarg, sorry about that
Old Jan 20, 2012 | 11:18 AM
Engine: 2.7L V6
Axle/Gears: 4.41
It happens . Good news is that the ring is readily available, even though it's $35 (the last time I looked anyways), and GM seems to possibly be running out...
http://redlinegoods.com/Firebird9802shiftboot.php All the way at the bottom of the page is the price list..
Old Jan 20, 2012 | 01:40 PM
Oh ok i see guys thanks. So do i need this? http://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313 Or the thing that You said Maverick, the shift boot bracket?
Old Jan 20, 2012 | 01:46 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I definitely would NOT get the plastic shift boot ring. GM made a crappy design decision on that one. Even being careful, the plastic ring breaks easily. Since you already have the metal one, I'd take the boot off of it (it just slides off through the slits in the bottom) and try to get it bent back into shape. Failing that, I'd get a new one.
Old Jan 20, 2012 | 04:34 PM
My other concern is the plate where the traction control thing was. What can i mock up to put there? And also thanks tons Maverick.I really appreciate your help
Old Jan 20, 2012 | 04:40 PM
Engine: 2.7L V6
Axle/Gears: 4.41
http://www.ebay.com/itm/97-02-Camaro...item3f12a20825
In the pic, you can see the compartment that fits in there, that I described above. I think I got mine for $15. There was another one recently, but I'm looking for an armrest, so I didn't get it (as I already have one).
Old Jan 20, 2012 | 05:02 PM
Ah ok. Hopefully theres one at the junkyard
1992 Trans Am
May 10, 2023 07:19 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Casey Meyers
Mar 2, 2016 10:46 AM
LittleFranks
Sep 17, 2015 12:22 PM
mav75
Aug 31, 2015 12:16 AM
