Ignition Lock Cylinder Replacement?
Old Feb 5, 2012 | 04:55 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Im looking at buying a new black GM ignition lock cylinder with keys for my 85. My ignition key now is stamped with an "A". Does it matter if I buy a new cylinder/key set and the key is stamped with a different letter?
Thanks.
Old Feb 5, 2012 | 05:12 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Ignition Lock Cylinder Replacement?
Once you replace the old lock clyliner with a new one those old keys are history.
Old Feb 5, 2012 | 05:25 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
So there is no physical difference in the way the lock cylinder fits into the column if the keys are stamped with a different letter?
Old Feb 5, 2012 | 09:54 PM
algershick's Avatar
Its not going to make any difference. I don't know if cylinders changed at all for the duration of third gen production, so just make sure that you get a correct cylinder/key for your model year.
Old Feb 5, 2012 | 10:35 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Awesome thats all I needed to know. Thanks!
Old Feb 6, 2012 | 11:50 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I think the only keys you need to worry about"if your keeping it original" is B48,B49 A-B The "A" is ignition key,the "B" is the hatch,doors etc.
Old Feb 6, 2012 | 04:35 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Id like to get one with the A key, but all I can find are ACDelco cylinders with C,D,or E code keys...
Old Feb 6, 2012 | 05:22 PM
DJP87Z28's Avatar
Simple question: Wht do you care about akey with a letter on it????
Old Feb 6, 2012 | 08:17 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
For originality sake, but the main question was if the letter on the key has a different letter, than is the cylinder different. The question was answered though.
Old Feb 6, 2012 | 08:25 PM
mantaguy's Avatar
Engine: 5.0 EFI
Are you looking for new keys,or the whole thing.
Old Feb 6, 2012 | 08:31 PM
mantaguy's Avatar
Engine: 5.0 EFI
found this on ebay,it is NOS it is for 85 camaro this would have the "A" key if it is NOS.
IGNITION SWITCH BLACK GM 1982-1987 EL CAMINO MONTE CARLO CAMARO G BODY
Item condition: New
Compatibility: See compatible vehicles
Time left: 15d 13h (Feb 22, 201208:01:54 PST)
Price: US $55.99
Old Feb 6, 2012 | 11:27 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Yep I was looking for the whole thing. Thanks.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 22, 2015 08:17 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
