Dome Light not Working
Old Feb 26, 2012 | 08:17 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
The dome light in my car is not working. Both metal clips/terminals that hold the bulb in place have power to them. Is this correct, or should only one of them have power to it?
Old Feb 26, 2012 | 08:20 PM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Re: Dome Light not Working
are you getting power in the 12V cigarrete insinder?
Old Feb 26, 2012 | 08:24 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Yes, the cigarette lighter works.
Old Feb 26, 2012 | 08:26 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
hmm.. hold on i will brb gonna go check my car. and see how it gets power.
Old Feb 26, 2012 | 08:38 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Are you sure the bulb is good?
Old Feb 26, 2012 | 08:42 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Yes, I have tried a few different bulbs.
Old Mar 1, 2012 | 06:27 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
If it makes any difference, the floor/courtesy lights do work. Not sure if they are wired together or not. Should both of the terminals have power to them?
Old Mar 2, 2012 | 01:43 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Perhaps the following will help:
TROUBLESHOOTING HINTS:
If none of these components (courtesy lights, cigar lighter and the dome and reading lights) work, check fuse by operating Horn
If several circuits don't work, check ground G200 (Behind I/P, left of steering column).
JamesC
Old Mar 2, 2012 | 11:55 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I have the same problem, but the cause of mine is the dome light button on the overhead console, it has a short in it. If I wiggle it just right the light will come on.
Old May 1, 2014 | 09:08 AM
CamroIROC-Z28's Avatar
I really need help!!!
I just bought an 86 Iroc z28. I was checking it out last night as soon as i removed the cigar lighter the dome light shut off. I also noticed the horn was working when i bought it but is not working right now. I am not so knowledged about these cars since they are preety old, that is why i need some help.
Old May 1, 2014 | 10:09 AM
sorrys70's Avatar
They are all on the same fuse. (I think) it should just be a 15 fuse
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
