possible to swap steering columns?
Old Mar 4, 2012 | 09:25 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
Ok, so just to explain, is it possible to swap a non-tilt steering column to a tilt steering column? if so then what years/models would be compatible with my 85 SC?
Thanks much!
Old Mar 4, 2012 | 11:11 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: possible to swap steering columns?
It is possible as I swapped a 87 tilt column into my 85 which was non tilt. I think the only columns that are different are the ones with the air bag which was 90 - 92
Old Mar 5, 2012 | 07:26 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
You can probably use any 3rd gen without air bags.
Old Mar 5, 2012 | 07:44 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
How hard is it?
Old Mar 5, 2012 | 08:10 PM
mantaguy's Avatar
Engine: 5.0 EFI
If you have some mechanical skills,no more than 2 hrs labor.Mostly just removing bolts and nuts,some elec.plugs,really not hard at all.Just take your time.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
