How to get to the convenience center?
Old May 12, 2012 | 04:16 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
What's the easiest way to access the convenience center on a 1989 Trans am? my flasher is on the fritz and needs replacing. I had to get to it before but it was a complete pain in the a$$ unbolting everything. Is there only a select amount of things to unbolt to get to it? I have a feeling I took off to much last time
Old May 12, 2012 | 09:58 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: How to get to the convenience center?
This is from the 88 Firebird service manual. I replaced the flasher on my 88 Firebird but I went went there four times before I found it. A real pain. The only thing I had to remove was the kick panel under the steering wheel. Maybe four screws. The reason I couldn't locate is because it's right above the ALDL and convenience center. Use a mirror and a light. Hope the diagrams help.
Attached Thumbnails How to get to the convenience center?-flasherloc.jpg   How to get to the convenience center?-flasherloca.jpg
Old May 12, 2012 | 10:30 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Just curious, what is the C210 for?
Old May 12, 2012 | 10:39 PM
antares57's Avatar
Seems to be stop/hazard/turn exterior lights.
Old May 12, 2012 | 11:15 PM
Axle/Gears: 3.45
That helped a lot, thanks!
Old May 12, 2012 | 11:21 PM
antares57's Avatar
No prob, anytime...good luck.
Old May 12, 2012 | 11:22 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I'm not 100% sure, but I believe that convenience centre is hinged on one side and has a quick release on the other so it can fold down and you can get to the components easily.
Old May 12, 2012 | 11:26 PM
Axle/Gears: 3.45
If someone could confirm this is true that would make my day
Old May 4, 2014 | 06:49 PM
aeddy85's Avatar
Car: 1985 IROC Z28
Engine: rebuilt 305 4bbl
Transmission: 5-speed manual
i used these pics to find the flasher on my 85 Iroc. After a few failed attempts, your diagrams led me right to it. Thanks!!!
Old May 4, 2014 | 07:40 PM
antares57's Avatar
Lots of great info in this forum. Just need to search or ask. Your welcome.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Eric-86sc
Sep 28, 2015 11:37 AM
