Horn not working
Old Jun 12, 2012 | 11:55 AM
Shepp84Z28's Avatar
Car: 1984 Z28, 2004 F-250
Engine: 305 in the Z28, 10-Cyl in the F250
Transmission: 5-Speed in the Z28, F2250=Auto
Horn not working
Hi,
I have a 1984 Z28 I recently purchased and the horn is not working. The guys said something about a clip or something like that. Any ideas?
Also, is it a real pain to remove the horn cover (as in easy to break any pins or clips holding the horn cap on)?
Thanks,
Shepp
Old Jun 20, 2012 | 07:12 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: Horn not working
Pretty straight forward. Grab the horn button and just lift it off the wheel. Any damage will already have been done from years of abuse. Disconnect the yellow wire from the horn and touch it to ground (any exposed metal on the wheel). If the horn sounds, your problem is the button. If it does nothing, check the fuse, and if that is good, check for power/ground at the horns themselves. If you have power/ground, replace your horns.
Will
Old Jul 10, 2012 | 02:31 PM
Shepp84Z28's Avatar
So I ended up pulling the cap off, and no go when I touched the yellow wire to metal. Since I don't have a volt/Ohm meter I had to send to a shop... So the guy there breaks my horn cap... but he says he has the horn working now (and as a bonus the interior dome light is working too)... I get a call to come get the car, horn is all set.
I get there, pay (240.00), jump in the car, beep the horn once it does beep but my horn cap falls off... and no more horn.
I tell the mechanic how much of an **** he is for breaking the horn cap, and that the horn (and interior light) are not working, but now I can hear the relay clicking (I guess the relay was fried before). However, I am not bringing my car to him again... ever, and perhaps I won't be using him for my day to day drivers as well...
So now I have no horn, no horn cap (but I do have a NOS in a box to put on after the horn is sorted, and I will put the cap on myself after that, not a mechanic thank you), and no interior dome light... It has me thinking maybe this is now a fuse issue...
Thoughts? Good mechanics in southern NH or Northeast Mass?
Shepp
Old Jul 10, 2012 | 02:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Horn and dome are on the same fuse. I'd check.
JamesC
Old Jul 13, 2012 | 08:49 AM
Shepp84Z28's Avatar
So I changed the ACC fuse (everything I read online seemed to indicate this was the most likely fuse for the horn), but nothing changed. Still no horn and no interior dome light. I did notice the ACC fuse I took out was fine and was a 20, I replaced it with a 30 (again, all indications from what I have read indicate this is a 30 not 20 amp fuse).
I'm not sure if there is any correlation yet but I noticed today (and I should have checked before I swapped out the fuse) that I no longer hear the relay clicking when I test the horn (touch the yellow wire to bare metal...
Very aggravating.. I hope I can talk the mechanic into giving me an inspection sticker w/o a horn...
Shepp
Old Oct 10, 2012 | 11:58 AM
axestrum's Avatar
the horn runs directly from the ctsy fuse in the fuse box to the relay in the junction box orange wire, which may be mounted under the dash just above your right knee,also contains the key in door chime,flash unit and horn relay,check for power from ctsy fuse to relay,the green wire from the relay runs to the horns in engine compartment,the black wire runs to your horn switch on steering column,pressing the horn button closes the circuit to sound horns.
Old Oct 10, 2012 | 12:03 PM
JamesC's Avatar
More info in the following link:
https://www.thirdgen.org/forums/elec...orn-fails.html
JamesC
Old Nov 25, 2012 | 10:21 AM
High~Cruzin's Avatar
Car: 89 firebird(going full TA custom)
Engine: sbc 383...LSX swap...in wrks
Transmission: 4L80E
Axle/Gears: 94 ws6 rear, 3:42 gears
Sorry for jumpin in on thread 1st off...but I'm deal with a horn issue that makes no sense. New relay(clicks loud), fuses are all good and as far as I know wiring is straight. Tried the (touching horn button wire to ground(metal surface) and horn makes a sort of popping sound...also does this when hooked up to button and grounded...any insight?
Old Nov 25, 2012 | 11:09 AM
JamesC's Avatar
Edit.
Old Jul 6, 2013 | 09:39 PM
Don Christensen's Avatar
Car: 1989 Formula - Red
Transmission: 700 R4
Axle/Gears: 3.73 Posi
And if the CTSY (Courtesy) fuse is blown, and the replacement blows, the first place to check is the cigarette lighter. My wife has a habit of dropping pennies into her lighter socket ......
Old Jul 6, 2013 | 11:20 PM
phasevariance's Avatar
Car: 1992 Camaro RS & 2014 Camaro SS V8
Engine: 305 & 6.2L
I'd make the mechanic fix all of it. Then find a new guy.
Old Apr 19, 2017 | 01:37 PM
jeremyb1988's Avatar
On Probation
Car: 1987 IROC-Z Camaro
Transmission: T-5 5 Speed
Will
I know its an old thread, sorry...its the ACC fuse right?
Old Apr 19, 2017 | 10:27 PM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
That's the one!
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
