cracked dash solution-micro suede
Old Jul 13, 2012 | 05:09 PM
Camaro-Drew's Avatar
Car: 92 rs Camaro
Engine: no engine now, some sorta sbc soon!
Transmission: none now, built auto oneday!
Axle/Gears: stock now, 9" one day!!
I had the typical cracked dash but didn't want to fork out $400 for a new one and I simply don't like dash caps/covers. So I decided to try my hand at reupholstering the dash pad. I norrowed it down to black tweed (old school styling) or black micro-suede(new school styling). I ended up going with the micro-suede. For any of you old school folks out there the procedure for laying tweed is the same. I'll skip all the minor details on filling in the cracks.
1. (if the edges of the cracks are bowing upwards) Use a cut off tool to trim the bowing portions off
2. fill in cracks with fiberglass. sand flush
3. fill in air pocket or dips in the fiberglass with bondo. sand flush
4. (option) good time to shave the side vents if you wish
5. use sand paper to scuff entire dash pad (promotes good adhesion)
6. thoroughly clean entire dash pad with soap and water, let dry
this is where I'll start the pictures..Cracks filled, side vents shaved
Old Jul 13, 2012 | 05:31 PM
Car: 92 rs Camaro
Re: cracked dash solution-micro suede
Now onto the supplies. All you need is the fabric and the upholstry spray glue. Got both from Joanns. The micro-suede was about $9 yard, picked up 2 yds but I'm pretty sure 1yd would've been enough. The glue was about $10 a can.
Now onto laying the fabric.
1. Spray down the tops and sides of the dash pad and bottom side of fabric with the glue
2. Lay down the fabric over the pad. (the glue is extremely sticky and dries fast, was unable to take pics for this reason)
3. Stretch fabric tight until whole top/sides of dash are covered (be very,very,very carefull not to get glue on top side of fabric)
4. make multiple slits in fabric over rear vent holes and fold under
5. Now onto the underside, flip over dash (make sure you have clean work surface to lay the dash on)
6. trim away excess material
7. spray underside edges with glue(be very carefull with glue overspray)
8. fold over edges and stick to underside (this part was a bit difficult so my wife helped here, she's a seamstress, she also cut and folded over the rear vents which was also pretty difficult)
btw: just wanted to give special thanks to my wife, we live in Phoenix and it was 111 degrees that day which put it at about 105 in the garage, and she toughed it out to help get this done!!!
Old Jul 13, 2012 | 05:33 PM
Car: 92 rs Camaro
Here's the finished product
Old Jul 13, 2012 | 05:34 PM
Car: 92 rs Camaro
Installed
BABY APPROVED!!!
Old Jul 13, 2012 | 05:38 PM
Car: 92 rs Camaro
Hope this was helpfull to someone out there, just a dirt cheap solution to those of you lookin to fix a cracked dash!!
Old Jul 13, 2012 | 06:13 PM
BADNBLK's Avatar
COTM Editor
Looks pretty good. Need more suede in other areas of the interior now
Cute kid!
Old Jul 13, 2012 | 06:15 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
That is very nice Camaro-Drew I will keep that in mind for my repair. Please let us know how it holds up in the heat, Thanks. PS Dad your wife has a nice smile, Good looking youngen also. Sorry.
Old Jul 13, 2012 | 06:29 PM
Car: 92 rs Camaro
Thanks guys, I appreciate it!!
Cute kid!
The dash was so flat, it made it easy for a first timer to do, I don't think I could pull off all the countors throughout the rest of the interior. Figure I'd be doing more harm than good.
Old Jul 13, 2012 | 07:03 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
looks great. Some of the new exotic hi end cars have suede. Ive always wanted to do nice recaros with leather / suede centers. do the dash top and door panels in the same style.
Again looks great.
Old Jul 14, 2012 | 08:07 AM
GPSkinzhut's Avatar
Car: 87 IROC Z, 2010 2LT
Engine: 305 TPI, 3.6 V6
Transmission: 5-Spd, 6-Spd
Axle/Gears: G92 3.45
that's pretty interesting actually. How well does bondo hold up with interior temps? I'd really love to see some micro suede on the interior plastics too.
Do it!
Old Jul 14, 2012 | 02:25 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Do it!
Bonodo should hold up ok. Id have used a micro balloon / GA combo myself as the feeler. Then the bondo as a skim coat on top.
GPSkinzhut,
Those seats would look great in my vert.. drrroooollll....
Old Jul 14, 2012 | 03:11 PM
GPSkinzhut's Avatar
GPSkinzhut,
Good to know.
Thanks! One Of the better investments I've made
Old Jul 14, 2012 | 04:46 PM
Car: 92 rs Camaro
GPSkinzhut,
I did use bondo as just a skim coat, fiberglass was the main filler, which is pretty versatile so I'm sure it'll hold. And I haven't the slightest idea what a micro balloon is but I'm defanately going to research it for future reference!
Old Jul 14, 2012 | 04:56 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
something Ive used in the aviation field for filler materials. VERY LIGHT weight. Very strong , etc..
http://www.ipmsstockholm.org/magazin...roballoons.htm
Old Jul 14, 2012 | 06:14 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It looks nice. I have a couple comments though.
If you filled the rest of the speaker grills in, it would look smoother, or if you do have speakers in the dash, perhaps open up the area and install a perforated grill similar to what the Firebirds use.
I would also make sure you use the good automotive grade (read: expensive) alcantera, otherwise it will turn purple in no time. The furniture grade stuff doesn't use UV resistant dies.
Old Jul 14, 2012 | 08:27 PM
Car: 92 rs Camaro
It's being built strictly for track use, it'll spend most the rest of its life under the safety of the garage, and our two drag strips in phoenix hold most of the grass roots local events at night, so hopefully the color will hold up, just wanted an inexpensive but decent looking way to cover up the cracks
Old Jul 15, 2012 | 07:01 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
i hope it has a good UV protection... because its going to fade
Old Jul 15, 2012 | 07:32 PM
blackjack12982's Avatar
That looks good! I definitely like it, just like every other 3rd Gen, my dash pad is cracked. I need to do something like this, I think it would make a world of difference in just general looks on the interior.
Old Jul 16, 2012 | 12:50 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Looks great!!
Old Jul 18, 2012 | 11:03 PM
david86camaro's Avatar
Car: 1986 Camaro
Engine: 2.8
This looks nice, I'm glad you posted it I have been thinking of covering mine with fabric of some sort, I have a dash pad and like it but the corners have cracked and now a crack has started over the years in the middle and the skill needed to repair and repaint is beyond my skill. I might have a chance at this, I also plan on doing the headliner to about the same way. I like the suede rather than a standard fabric.
Old Jul 18, 2012 | 11:14 PM
Car: 1986 Camaro
Engine: 2.8
I also was thinking about doing this on my center armrest/glove box cover but I would need to find a flexibe glue and a way to cover the "seams".
Old Jul 22, 2012 | 12:30 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
NICE WORK!!!! Suscribed.
Old Jul 27, 2012 | 09:19 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Amazing job! I've been thinking about doing something like that for my two cars but had never seen anybody do it. Thanks for posting this, very helpful!
Old Jul 28, 2012 | 12:03 AM
Car: 92 rs Camaro
Thanks for the compliments guys!!!!
Old Mar 15, 2014 | 09:18 PM
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
Looks awesome dude! I will be doing this to my dash for sure.
tyeo098
Nov 30, 2015 06:27 PM
MantyZ28
Nov 8, 2015 06:54 PM
codeysabatini
Sep 20, 2015 11:36 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
Stryker412
Sep 7, 2015 09:11 AM
