Carpet installation
Old Aug 7, 2012 | 09:49 PM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
Carpet installation
I have seen few carpet ads which either they sell one piece all together, or the driver/passenger separately?
Do they come separate to avoid removing the console? Are they cosmetically look different?
Old Aug 8, 2012 | 02:49 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Carpet installation
Usually (from my Camaro experience), it's two sections. One is from firewall to backseats and the second is for the hatch area. Spend a little more and buy with as many pre-cuts (console area) as possible to make installation easier.
Old Aug 8, 2012 | 03:03 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
They don't come side to side,their front or back!!!!
Old Aug 8, 2012 | 03:26 PM
LHernandezJr's Avatar
Old Aug 8, 2012 | 08:34 PM
podiatra's Avatar
Engine: 350 swap
Hey, thanks for the input. Very helpful.
Old Aug 8, 2012 | 08:59 PM
Z28Johnny's Avatar
I just did carpet and everything already said is correct. However, you could do it without removing console. You can cut out the old one and then cut a u shaped channel and install the carpet around the console and tuck it in. I removed the console...I think it is easier this way.
Old Aug 8, 2012 | 09:33 PM
podiatra's Avatar
Engine: 350 swap
How difficult is to remove the console?
Old Aug 8, 2012 | 09:34 PM
podiatra's Avatar
Engine: 350 swap
Or I should say time consuming instead?
Old Aug 8, 2012 | 09:38 PM
mantaguy's Avatar
Engine: 5.0 EFI
10 minutes,3-4 screws,what's the big deal,do it right!!!
Old Aug 8, 2012 | 10:03 PM
Z28Johnny's Avatar
Not hard. The bolts are all obvious, unplug a few plus, remove shift ****. Just be careful with the window switches they could be brittle and they are expensive
Old Aug 9, 2012 | 06:02 AM
Old Aug 9, 2012 | 07:19 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
Originally Posted by motobooks
And you'll also have to remove the e-brake handle and make sure it is up and out of the way.
Just to clarify on this, you don't have to remove the e-brake assembly from the car, if I remember right, you just loosen the setscrew on the handle itself and slide it off so that you can get the console over/off the lever...I think motobooks' comment may lead you to think you need to remove the e-brake all together and I don't want you to mistakenly think that you need to remove the whole thing and be intimidated.
Swapping the carpet is a decent first project, it'll help you see how things go together and instill some confidence so that you can handle some larger projects later on. As others have said, go for the two peice precut carpet from a good vendor and take your time doing it, bag and label the screws and bolts that you remove, take pics of how things go together when you're taking them apart, whatever you have to do to make yourself comfortable with doing it and if you run into any problems, don't freak out. Remember, you've got an entire forum of people supporting you that can usually just look at a picture of a bolt or a hole and tell you exactly where or what goes there!
Old Aug 9, 2012 | 05:18 PM
jaben2's Avatar
Just figured I would post for anyone else looking. I came across this post when doing some more searching for carpet.
I found another valid code for 25% off at yearone.com code is PARTS8 and is good until 8/16 It was enough to get me to finally order my carpet, and insulation.
Old Aug 9, 2012 | 08:54 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
I really don't know how you can replace the carpet w/o removing the console. For carpet I recommend 1A Auto. Add some thermo insulation underneath while your at it.
Old Aug 10, 2012 | 07:59 AM
Junqueboi's Avatar
Unless your carpet is literally torn or you are changing colors, you can remove it, take it to a self-serve car wash, and pressure wash it. The carpet in these cars is tough & will take it & will look like new when you're done.
I did this again last week on some carpet I scored from a '91 RS at the local scrapyard. The t-tops had been left out & the carpet was stinky & matted..but it looks like new now.
It's more work buying used carpet if yours is shot but it's a lot cheaper & more fun
Old Aug 11, 2012 | 07:39 PM
podiatra's Avatar
Engine: 350 swap
This is great idea! It worth trying.
Vintageracer
Jan 10, 2020 05:33 PM
lee01
Apr 9, 2016 01:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MORREALE5
Sep 13, 2015 09:16 PM
