89 camaro rs dash lights and shifter lights won't turn on?
Old Aug 27, 2012 | 12:10 AM
dicestacker's Avatar
I can't figure out why. I mean accidently touched to wires together for the shifter light and now none of them will turn on. Any ideas?
Old Aug 27, 2012 | 12:12 AM
Marine_Marauder's Avatar
Car: Black 1991 Z28
Engine: 5.7 TPI
Transmission: Automatic
Axle/Gears: I have no Idea
Re: 89 camaro rs dash lights and shifter lights won't turn on?
You popped a fuse.
Old Aug 27, 2012 | 12:14 AM
I checked the fuses under the dash and none of them are blown.
Old Aug 27, 2012 | 12:35 AM
Car: Black 1991 Z28
Engine: 5.7 TPI
Is it just the lights, or are the gauges not working?
Old Aug 27, 2012 | 12:53 AM
Just the lights. All the gauges are working fine.
Old Aug 27, 2012 | 01:04 AM
Car: Black 1991 Z28
Engine: 5.7 TPI
I suspect the dimmer switch.
Old Aug 27, 2012 | 01:10 AM
Even though when I pull it back it turns the head lights on? Also if I turn it to the left it turns the dome lights on?
Old Aug 27, 2012 | 01:25 AM
Car: Black 1991 Z28
Engine: 5.7 TPI
Most of what I'm finding on the web points to a bad negative connection. You should have one in the driver's footwell. Make sure it has a good ground.
Old Aug 27, 2012 | 01:28 AM
Car: Black 1991 Z28
Engine: 5.7 TPI
http://www.ehow.com/how-does_5022351...itch-work.html
Old Aug 27, 2012 | 01:29 AM
I'll check it out tomorrow. Hope that works. You think I could have also blow a relay by touching those wires?
Old Sep 3, 2012 | 12:31 AM
How do I pull the whole instrument cluster out? I ask this because I believe that the wiring diagram says that there might be circuit breakers behind it.
Old Sep 3, 2012 | 12:38 AM
kauboy's Avatar
Car: 83 Z28 Crossfire
Fuse probably
Old Sep 3, 2012 | 12:41 AM
Ok still not sure how to get to it.
Old Sep 4, 2012 | 01:21 AM
Car: Black 1991 Z28
Engine: 5.7 TPI
Loosen the bolts that hold the steering wheel in place enough to drop it down 1-2 inches, and the cluster slides right out.
But, no circuit breakers are behind it.
justin57
Aug 20, 2015 07:05 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
BrianI
Aug 9, 2015 11:52 AM
