Rear view mirror movement
Old Sep 4, 2012 | 01:45 AM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
This might seem like an odd question, but is is possible to get the mirror to stop shaking? It seems to have gotten worse lately, and I wonder if there is some kind of adjustment for it that would fix it.
Old Sep 4, 2012 | 01:59 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Rear view mirror movement
i think theres mounting bolt from the inside.
Old Sep 4, 2012 | 02:06 AM
Here you go man....
doormirror1.gif?t=1346742372
doormirror2.gif?t=1346742374
Old Sep 4, 2012 | 02:08 AM
If your reffering to the mirror on the windshield, there is a small allen wrench bolt that can be tightened at the base where the shaft meets the glass.
Old Sep 4, 2012 | 02:19 AM
actarnoff's Avatar
Engine: 355 TPI
That's adjusted pretty tight. It seems to come from the actual ball joint that the mirror hinges on.
Old Sep 4, 2012 | 04:28 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
When that gets worn out that much there's not much you can do besides replacement. I've got some good tight used ones if you have the one with map lights. PM or email me your email address for pics and other info if interested, Henry
Old Sep 5, 2012 | 12:27 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Unless your keeping the car stock I tried this sleek 10"x2.5" as opposed to the stock and IMO it looks very clean and once you get used to the 10" long mirror the others seem lacking.Hold them side by side and you will see what I mean. (there's a 2" difference in mirror length.)so its not extreme.
= http://www.oreillyauto.com/site/c/de...0313&ppt=C0329
Should be able to slide off the old one and just slide the new one onto the window existing mount .Done
Old Sep 21, 2012 | 11:00 AM
DAIGS1985's Avatar
Car: 1985 T/A
Engine: 355 TPI
My old mirror used to do the same i tried to use RTV on the ball to add more "material" so it would stop moving but it didnt do anything i ended up just using a another mirror from a donor car
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
mizz0313
Aug 12, 2015 06:45 AM
89FormulaMan
Aug 10, 2015 10:01 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
