98-04 blazer overhead console
Old Oct 19, 2012 | 02:10 PM
system155's Avatar
Car: 89 camaro iroc, 89 camaro rs
Engine: 350-iroc / 305 rs
Transmission: 700r4 / t5
so i want to put a overhead console in my camaro and i was looking at different thing then i came across this
its a 98-04 blazer console on a 2 gen camaro
and want to no if any one has done this or if this is do able
i also no i would have to mod the console a little bit
Old Oct 19, 2012 | 02:17 PM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
Re: 98-04 blazer overhead console
Thats really clean looking.
Old Oct 20, 2012 | 11:54 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
I did this using a 2nd Gen Console into a 1st Gen S10 Blazer. It is a project simple to do. Do a search on any of the S Truck Forums. There is a wealth of knowledge on this...
First you will need the overhead console. The console was in many vehicles including, Blazer, Jummy, Astro Van, Tahoe, Suburban, and some others. There are 2 different displays. One have Temp/Compass. The other also displays Engine Info. You will want one that only displays temp/compass as you will need the ECM from the donor vehicle for the engine info.
You will need the console and temp sensor from the same vehicle. the temp sensor is mounted to the front of the vehicle under the hood by the radiator. The compass is internal near the front of the overhead.
There is 2 mounts you will need to fab. The easiest was to do this is with a couple wood blocks and some epoxy. You will defiantly will need to do this with the front. The rear may be able to use the existing mount. This is by far the most difficult part. Then there is 6 wires. Ground, Constant Power, Overhead Power (these 3 should already be going to your existing overhead light), Dimmer, and Temp (from the temp sensor). The Temp sensor will also have a ground.
Old Oct 20, 2012 | 12:01 PM
loomdog32's Avatar
Car: 82 Camaro Z28
From top to bottom -
Wire harness for Overhead display
Compass
Temp Sensor
100_1398.jpg?t=1339382305
Note the main harness, I only have 4 wires exposed: Ground, Temp, Dimmer and Constant Power.
And the Temp sensor has 2 wires exposed Ground and Temp.
Underside of the front of the console
100_1396.jpg?t=1339382304
Note the front mounting point is a single screw in the front middle.
Underside of the Rear of the Console
100_1397.jpg?t=1339382304
Note the wires 3 wires: Ground, Constant Power and Overhead Power. I ran these thru the console and merged them with the wires for the display making a single 5 wire bundle.
Also Note the dual Mounting Points.
100_1393.jpg?t=1339382302
Old Oct 20, 2012 | 12:18 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
this is cool. Im gonna try this
Old Oct 20, 2012 | 01:26 PM
loomdog32's Avatar
Car: 82 Camaro Z28
I decided to sell my extra console (it is the same as pictured above). Note it has the display that also shows engine info.
https://www.thirdgen.org/forums/inte...ml#post5406521
Old Oct 21, 2012 | 09:17 PM
system155's Avatar
thanks alot for the info on this as u saved me a bunch of time on try to do this
Old Oct 22, 2012 | 02:48 AM
Podium's Avatar
Awesome. Been thinking of something like this
Old Oct 22, 2012 | 09:53 AM
82tarecaro's Avatar
That looks great in the 2nd gen car, but I don't think there is enough width on a third gen with t tops to fit it in the center.
Old Oct 22, 2012 | 10:06 AM
Jeremy_worden's Avatar
Car: 1991 camaro RS
Engine: 3.1 v6 LHO
Transmission: 5 speed
Axle/Gears: 3.26
Got to give this a shot
Old Oct 22, 2012 | 02:19 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Ill be able to confirm this later tonite I just picked one up today
Old Oct 22, 2012 | 03:44 PM
system155's Avatar
Cool when u get done post some pics
Old Oct 22, 2012 | 05:35 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Well here's pics of the console
Old Oct 22, 2012 | 11:03 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
So its a little wider than allow not by to much ill get pictures in the afternoon tomorrow but I had to use a lonng screw up front and drill two new holes in the back due to the blazer screw holes being wider than the ttop bar will allow will need to mold it into the headliner and carpet it but dont have headliner to work with right now ill start on the wiring tomorrow also.
Old Oct 24, 2012 | 11:54 AM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
its in! its also going to need a bit of trimming but doesnt look like a huge deal heres a pic subscribe to build thread in my sig for furture updates/more pics.
Old Oct 24, 2012 | 02:40 PM
Faded's Avatar
Car: '91 Firebird
So basically it doesn't fit.
Old Oct 24, 2012 | 02:55 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Going to try and bend it in a bit by applying heat to form the plastic
Old Oct 25, 2012 | 08:57 AM
Car: 1991 camaro RS
Engine: 3.1 v6 LHO
Axle/Gears: 3.26
More pix
Old Oct 25, 2012 | 11:50 AM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Not sure i like how long it is may try and find a shorter one but heres more
Old Oct 25, 2012 | 12:00 PM
Car: 1991 camaro RS
Engine: 3.1 v6 LHO
Axle/Gears: 3.26
Wow I Relly like it looks epic great job
Old Oct 25, 2012 | 12:16 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
thanks it needs some trimming and bending done to fit properly though
Old Oct 25, 2012 | 12:54 PM
82tarecaro's Avatar
I am curious how it will fit with the headliner
Old Oct 25, 2012 | 01:56 PM
loomdog32's Avatar
Car: 82 Camaro Z28
It looks like it is slightly wider than the t-bar roof. Better hope your t-tops dont leak!!
Other than that, it does look good!!
Old Oct 25, 2012 | 02:58 PM
MeenZ28's Avatar
Transmission: A4
Now that I've seen it in a 3rd gen... I'm out. Thanks for being the guinea pig.
Old Oct 25, 2012 | 03:08 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Interesting. Looks great in that 2nd gen. It's a nice console and a great idea. Something like this would more than likely work great in my hardtop. The lighting alone would make it worth while.
Old Oct 26, 2012 | 08:31 AM
Faded's Avatar
Car: '91 Firebird
Old Nov 6, 2012 | 01:28 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Ive come close to doing this in my other car that was ttop..but that car is gone.I will be doing this in my new hardtop car though which should be a much better fitment vs the ttop.They are a long overhead but that doesnt bother me as it has a wide light spread.I miss my spot lamps at night for quick things..instead of turning on all the interior lights from the dome switch lol.
I suppose you could easily heat the sides of it in to fit ttops better,or as i had planed was to cut small pieces of abs plastic and fit it in the gaps and seal it from the elements.Not a big issue..just gotta be creative.
Old Jan 17, 2013 | 01:14 PM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
where would the screws go in? through the top of the car?
Lbibb
May 5, 2016 12:00 AM
ndndndnd
Sep 28, 2015 08:00 AM
MORREALE5
Sep 13, 2015 09:01 PM
scottmoyer
Sep 7, 2015 07:06 PM
Jetmeck
Sep 4, 2015 12:29 AM
