Grant Steering Wheel
Car: 1991 Camaro RS
Engine: 305 TBI
I am looking at installing a Grant steering wheel in my 91 Camaro. The airbag is in poor condition and rather than replace it I thought I'd upgrade the steering wheel. Are there any "Gotcha's" that I should know about? Will the standard installation kit work? All of the Grant listings stop at '89, I think because of the airbag install.
Any information or help would be appreciated.
Slowly upgrading on a budget.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Grant Steering Wheel
it has been done with the 89 kit . i did it , many others have . the only thing is the collar on the steering column needs to be trimmed 1/8" all the way around . be very carefull doing the trimming or finish will look like crap . i used a very fine tooth hobby saw blade by itself . use masking tape on collar before starting . disconnect batt. & airbag before starting . before starting anything
more . there are many threads on this install . read them "ALL" before you start . good luck .
more . there are many threads on this install . read them "ALL" before you start . good luck . Member
Car: 1988 camaro
I have a grant in mine bought it with it hate it turn signal don't shut off when making turn and No horn don't know if it was hooked up right it a super small one thu
Car: 1991 Camaro RS
Engine: 305 TBI
thanks guys, ive seen them in alot and as the post said, i was thinking of replacing, the horn isnt much of an issue for me as say the turn signal, but i mean i could, most likely, get use to dealing with that, but, wanted a different one and wanted to see how hard they were and uncle tom, i tryed looking up some, but never really specified install instructions..... newbie move hahah, but thanks guys,i will do some more homework!
Car: 91 formula
Engine: 350 tuned port. bolt ons
I have done mine last year in my 91. You can cut the hub adaptor instead of cuting up a colum. Its cheaper to replace the 10 dollar hub if you mess up. Also dont forget to take car of that annoying srs dash light. I still have mine in at its annoying to drive at night lol.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
no trimming needed, with alum 1/8 spacer under the hub adapter cover.
you came make it out of 1/8 sheet alum.
drop it ontop of the hub adapter.
drop on your hub adapter cover (the black bell looking thing) marked with a 27 most of the time
then your spacer and wheel... easy easy
Car: 1991 Camaro RS
Engine: 305 TBI
but thank you all who told me about the easier fixes, i will need to do some extra homework, but as long as it works, and i dont need like a whole new column, i am not afraid to do a little tweeking to make things work, thanks guys!!
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
