Can someone help me identify and find these interior parts
Car: 1987 Chevy Camaro Iroc Z
Transmission: Automatic (700R4)
I like these door panels. Where can I find them? Also I have power windows. I prefer new, black. My interior is gray, I am thinking about changing it to black.
And
I notice some thirdgens have this platform, cover, whatever you call it for there t tops. Did they come standard or aftermarket? Where can I get one?
And
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
Re: Can someone help me identify and find these interior parts
you can get those door panels from classic industries, although they will be aftermarket and not OEM. But you might be able to find them in late model camaros, my 92 had that same style just in red.
For the rear cover thing, where are you located, I happen to know where one of those are that the owner would be willing to part with. I believe you will need to recover the carpet area though.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
message this guy he has tons of interior parts.
https://www.facebook.com/photo.php?f...type=1&theater
The cover requires the rear plastic panel also. It has a lip designed into it to rest the lid on and a lock tab so the cover can lock. Be sure to get both pieces.
That cover you have pictured looks like something somebody made themselves. The original cover should have a handle and a lock.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Car: "Nina" 1988 Trans Am GTA
Engine: TPI 305 V8
Those door panels are from an '88 Sport Coupe Camaro. PM RCAR7395, he is known for pulling these (check his avatar haha) and can usually get a black set.
-Jack
-Jack
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
There are also 4 studs on the vertical part of the floor.These are for the hinge on the security lid, i think thats what its called.
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
A guy on here runs a Facebook site called "this week in camaro/ used parts" he has what you are looking for his name is Jason goes by thirdgencustom
The load floor panel was an optional item. Not sure how many years it was available, but it was for sure available in 92 as an option. It also was included in the 6-speaker Bose Radio option. Two 6 X 9 speakers were mounted on the panel.
I got one of those for my 92 RS when it was new and while installing the hinge bolts, I found out the hard way that the gas tank is very near the vertical area where the hinges mount.
I had an '82 with it so it was available for the entire 3rd gen run. The speakers that were mounted in it for the Bose system were 4" speakers, not 6x9s.
Engine: LS1, LB9, L03
That's exactly why I haven't tried to install mine yet...and your post confirms my suspicions.
Were you able to mount the hinges successfully? If so, how? Did you have to remove the gas tank to be sure that you weren't drilling more holes into it?
You can see in this pic from when I had my interior apart - there are supposed to be 2 mounting tabs welded to the car to mount that shelf.
While the gas tank was out for repairing the hole I drilled into it, I finished drilling the necessary holes. As I recall, there were bolts available from GM for mounting the hinges, but any standard hardware bolts would work.
Yeah, the tabs are spot welded at the factory, but only on cars that had the option. I'm hoping you're right about the dimples, that would make my job much easier!
Yeah, that's definitely the way to do it if you have the gas tank already out. I may end up replacing my tank just because my car's been sitting since 2005, and if that's the case, I'll go ahead and put a new fuel pump/sending unit in and drill the bolt holes while it's out.
If my gas tank is good, I may just save this cargo divider project for a later date...thanks for the info nonetheless though!
actually the rest lip is 2 steel pieces welded to the rear of the car, I know because I added it to mine because of the lid always sagging too low. The lock tab secures to one of the 2 sheet metal brackets. There's only a hole in the rear trim panel where it pokes through.
Keep in mind that mine is a 92. Earlier years may be as you described.
Yes, the rear panel is different in that it has a ridge but it will not hold the cover up properly without the metal tabs as the panel bends out the way easily and the cover drops down too low. Ask me how I know.....
Here's a pic from the panel off my 82 TA
different styles lock bracket holes
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
And
And
That one is mine, and 82tarecaro is correct. I had that piece made to cover the stereo amp and sub installed in the well. No hinge on it, it lifts off.
1992 Trans Am
May 10, 2023 07:19 PM
Linson
Aug 21, 2015 02:12 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
