My digital dash swap thread (Pic heavy)
Old Feb 9, 2013 | 07:52 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
So I decided to make the change from analog to digital for my 89 Trans Am GTA and have noticed that there hasn't been a thorough thread made on it so I thought that I might as well start one to help people who are wanting to do the same.
This is how the car was
Old Feb 9, 2013 | 07:53 PM
Axle/Gears: 3.45
Re: My digital dash swap thread (Pic heavy)
Making a start on it, removed shifter plate and removing steering wheel
Old Feb 9, 2013 | 07:54 PM
Axle/Gears: 3.45
Removed the cluster and removing dash harness
Old Feb 9, 2013 | 07:57 PM
Axle/Gears: 3.45
This is the stage I'm basically at now, removed the dash harness and started unplugging the wires in the harness, got most of them unplugged. Having a bit of a hard time figuring out how it connects into the engine bay
Old Feb 9, 2013 | 08:01 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Subscribed! Looks great so far haha, This is something I've been wantin to do
Old Feb 9, 2013 | 08:13 PM
Axle/Gears: 3.45
Welcome! I'll have more pictures of progress tomorrow, time to give my bleeding hands a break
Old Feb 9, 2013 | 08:43 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Understandable haha! Do you have all the sensors and wiring to make it all of it functional? Also noticed you have steering wheel controls with an aftermarket radio, does the controls work with the radio?
Old Feb 9, 2013 | 09:06 PM
Axle/Gears: 3.45
I sure do! I bought everything needed from a member of this board. The steering wheel controls do not currently work with that head unit, however there is an adapter that I plan on getting that will make them functional.
Old Feb 9, 2013 | 09:17 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Awesome! what all is needed?
Old Feb 9, 2013 | 09:31 PM
Axle/Gears: 3.45
The digital dash itself, the specific digital dash wiring harness for the dash, taillights and headlights (not the same as the analog one) all the sensors, washer bottle with float sensor in it and push button ac unit
Old Feb 9, 2013 | 09:49 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Will it malfunction without the washer bottle float and sensor?
Old Feb 9, 2013 | 09:57 PM
Axle/Gears: 3.45
It will all still function as it should but if you're missing sensors the driver information center (little display that shows the car and scans for issues) will come up as undetected and will show as an error
Old Feb 9, 2013 | 10:41 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Well if I do the swap I guess I'll have to hunt down my washer reservoir and re drill the holes. Thanks for the info!
Old Feb 10, 2013 | 08:07 PM
Axle/Gears: 3.45
*UPDATE*
Discovered a dealership installed security system that took a while to take out
Old Feb 10, 2013 | 08:08 PM
Axle/Gears: 3.45
Managed to finally disconnect the plate that connects the headlight harness to the dash harness so the are by the dash is completely gutted out nowMy digital dash swap thread (Pic heavy)-k03nm09.jpg
Old Feb 10, 2013 | 08:10 PM
Axle/Gears: 3.45
Working my way to pulling out the harness going to the trunk, found it easiest to cut through the carpet to get the the wiring. (carpet is getting replaced but I was still cringing)
Old Feb 10, 2013 | 08:57 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Holy crap at the wiring, I was surprised how much wiring was in these cars when I pulled the carpet out. Well at least when you get done with old harness you can make some money off it haha
Old Feb 11, 2013 | 09:17 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Good to see you are putting it in. There is alot of wiring that goes into the dash as it works or sences everything in the car. Cant wait to see it done in the car
Old Feb 11, 2013 | 10:43 AM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Wow, i thought about doing a dig dash, now I'm over it after seeing this !!
You are brave - thats some serious doing and un doing ... GOOD LUCK.
Keep the pics coming.
Suggestion - not that you need more to do, but now would be a good time to throw in a remote start kit.
Old Feb 11, 2013 | 12:05 PM
carlos64030's Avatar
Car: 1991 Trans Am GTA
I'll be installing a digital dash into my '91 Trans Am GTA as soon as the weather is consistently warm. I'm replacing the entire interior in my car, so that'll be the perfect time to do the dash. I already have an '88 donor car with a digital dash setup, which should make the swap somewhat easier since I'll be able to see how everything is laid out in each car.
Old Feb 11, 2013 | 02:02 PM
RockShowTrader's Avatar
Car: 1988 GTA
Holy crap. I have a digital dash in my 88 GTA and wanted to swap TO an analog. No way in hell would I dare attempt that project after seeing this posting. You are brave, sir.
Old Feb 11, 2013 | 03:08 PM
Axle/Gears: 3.45
That's basically what I'm doing too, I thought If I've pulled basically everything out, I might as well take everything else out too and start replacing/restoring it all. I have a t56 and 350 tpi swap to do after this too. Bus busy busy
Old Feb 11, 2013 | 03:11 PM
Axle/Gears: 3.45
Good to hear from you again! I was going to pay the shop to do it but then I looked at all the work involved and realized it would cost me an arm and leg so I decided to just bite the bullet. So far so good, only thing I'm concerned about is where some of the sensors go
Old Feb 11, 2013 | 03:23 PM
Axle/Gears: 3.45
I'm a little stumped here, this is the wiring for the analog hvac controls. Should I delete them or can they be left there because I know the plug ins for the push button hvac controls are electric connectors
Old Feb 11, 2013 | 03:32 PM
Axle/Gears: 3.45
That's a great idea, would it be feasible to do even though the vats system needs to detect the chip in they key to start the engine?
Old Feb 11, 2013 | 03:39 PM
MikeMN's Avatar
Car: 1988 Trans Am GTA and 1979 10th Anv
Wow, that looks like a lot of work, I am glad my GTA has a digital dash already.
Old Feb 11, 2013 | 03:49 PM
Axle/Gears: 3.45
Rub it in
Old Feb 11, 2013 | 09:41 PM
MikeMN's Avatar
Originally Posted by Firechicken86
Rub it in
Just saying, I hope it all works out for you.
Old Feb 11, 2013 | 10:18 PM
MikeMN's Avatar
Old Feb 11, 2013 | 10:35 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Bypass the VATS. I did it on mine, easiest thing ever.
Old Feb 11, 2013 | 10:36 PM
MikeMN's Avatar
Sorry if I offended you Firechicken86, I am a new member here as you can see by my post count, I am looking forward to participate on here as well as getting advice from other members on here.
Old Feb 12, 2013 | 12:03 AM
Axle/Gears: 3.45
Here's my progress for today:
Peeled back the rear carpet to get to the fuel sensor, nice to see an unmolested gas cover (fuel pump hatch)
The sensor was a pain in the a$$ to remove and I didn't want to break it by prying it off so I just cut the wires because the one for the digital dash is the same and I'll just connect it to that one
Didn't have the right size torx head to remove that metal bar that holds the plastic trim in place and the stores were shut so I had to remove the taillight harness with the trim in the way. Not fun!
Old Feb 12, 2013 | 12:05 AM
Axle/Gears: 3.45
Now you see it
Now you don't!
Finally removed all of the interior analog harness! all that's left is the headlight harness and the hvac harness
Old Feb 12, 2013 | 12:06 AM
Veaceonee's Avatar
maybe its just me..but I can't see your last 5 pictures. Just little squares
Old Feb 12, 2013 | 12:07 AM
Axle/Gears: 3.45
Not at all! I was just lightheartedly joking Welcome to the forum! You'll find everything you'll ever need here, it's an awesome place. Thanks for that diagram too, it really helped clear a few things up.
Old Feb 12, 2013 | 12:09 AM
Axle/Gears: 3.45
Hmm, I think I know what's wrong. Imgur wasn't working for me and I had all of my pictures om my gmail so I just uploaded them from there. I'll upload them again from another hosting site.
*Edit* Should be fixed now
Old Feb 12, 2013 | 05:28 AM
MikeMN's Avatar
Old Feb 12, 2013 | 05:52 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
You can work around that, but it's unsafe to put a remote starter in a manual transmission car. No matter how much you tell yourself you will never leave it in gear.
Old Feb 12, 2013 | 05:59 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
There are 3 black boxes the control the electronic HVAC in a digital dash GTA. A pushbutton control, a vacuum distributor, and a blend door motor. I have pics of them if you require.
Old Feb 12, 2013 | 06:01 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Top pic in post #32 you cut the fuel pump power and sending unit. Better make sure you get a super clean connection on that one, the fuel pump needs all the voltage it can get. Never ever use a crimp connector, especially here.
Old Feb 12, 2013 | 03:00 PM
Axle/Gears: 3.45
That would great if you could. Does this means I should unscrew the black airboxes attached to the dash and pull out the hvac harness that's in there?
Old Feb 12, 2013 | 03:01 PM
  #42
Axle/Gears: 3.45
I'll definitely be soldering the wires directly together
Old Feb 12, 2013 | 09:55 PM
  #43
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Not sure on the manual HVAC, but I believe all wiring and vacuum is within the control head.
On the electronic type, there are 3 seperate components. These are pics I have of them from the connector ends:
Attached Thumbnails My digital dash swap thread (Pic heavy)-gta-climate-control-connectors   My digital dash swap thread (Pic heavy)-gta-climate-control-connectors   My digital dash swap thread (Pic heavy)-gta-climate-control-connectors
Old Feb 12, 2013 | 11:33 PM
  #44
Axle/Gears: 3.45
Looks like the vacuum distributor and the blend door motor wasn't included in the harness that I bought.
Old Feb 13, 2013 | 06:19 AM
  #45
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Push button control will not work without all 3 components. Although digital dash cars ALWAYS came with the pushbutton controls, is you cannot find those other 2 boxes, I can't see any reason why you couldn't leave the manual controls in there. I must assume the HVAC control head connector will differ between manual and electronic, so you would have to decode the wires on the electronic harness in order to use them on your manual control.
Old Feb 13, 2013 | 10:15 AM
  #46
Axle/Gears: 3.45
I just talked to the guy I bought it off and he's going to have a look to see if he can find them so fingers crossed
Old Feb 13, 2013 | 10:56 AM
  #47
Jeffs82TA's Avatar
If it works anything like my 90 Y-body it will have a a/c controller like this.
Most vents are still vacumn controlled but the blen-door uses and electric motor. I would venture to say you will end up changing the heater box where this beln-door is. There will probably be a couple sensors for interior heat as well as maybe exterior heat (if it works like my Y-body)
Old Feb 13, 2013 | 12:27 PM
  #48
Retrostylz's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L 350
Transmission: Automatic 700R4
What did I get myself into!?
Looks like I've got quite the spring cleaning project ahead of me.
Glad that you made this either way, it will be a big help in my conversion! I'm going to start gutting everything in my car next week.
Old Feb 13, 2013 | 09:07 PM
  #49
Man... I'm SOOOOO freakin' glad I have a donor car to get all the parts from to do my swap.
Old Feb 13, 2013 | 11:50 PM
  #50
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
i often thought of doing this in my camaro, i eventually decided on an option that'll probably be alot of the same work, but is different, anyways props to you, its a BIG project because of all the tedious diss-assembly and wiring, goodluck can't wait to see it finished
