Bulb for gear shift indicator???
Old Feb 22, 2013 | 04:23 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
What the hell is that bulb for teh gear shift indicator? looks like its hard wired right in..
How do you replace that thing and what the hell is it???
Old Feb 22, 2013 | 05:30 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Bulb for gear shift indicator???
I think the socket either pops in and out or its a quarter turn type socket
Old Feb 23, 2013 | 01:22 PM
Roc Me 2's Avatar
Car: 1989 Iroc
Engine: In the works!!!
Axle/Gears: 9-bolt, 3.73 gears
I thought it was a quarter turn and it came out. They are usually 194 bulbs.
Old Feb 23, 2013 | 02:17 PM
insomniac's Avatar
Engine: 5.7 L98
its all 1 piece
Old Feb 23, 2013 | 04:13 PM
TTOP350's Avatar
I was thinking you hadnt pulled it out of the shift indicator yet.
That just pulls out like a dash bulb but its smaller.. (I think)
Old Feb 23, 2013 | 04:15 PM
insomniac's Avatar
Engine: 5.7 L98
i tried but that **** wont budge.. are you sure?
Old Feb 23, 2013 | 04:20 PM
TTOP350's Avatar
Its a lil booger
Old Feb 23, 2013 | 04:39 PM
insomniac's Avatar
Engine: 5.7 L98
Its a lil booger
yeah if i grab it hard enough to pull it out its gonna break off
Old Feb 23, 2013 | 05:03 PM
TTOP350's Avatar
Thats what she said
Check the factory service manual or the owners manual. It'll have a listing for every bulb then you can see how its together
Old Feb 23, 2013 | 07:26 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
It's a 37 (IIRC) and it is a royal PITA to get out of there. I think I grabbed mine with pliers when I changed it years ago (not running it now). It's tougher than you think because it's so small.
Old Feb 23, 2013 | 07:39 PM
insomniac's Avatar
Engine: 5.7 L98
whats a 37 iirc?
Old Feb 23, 2013 | 09:00 PM
Engine: 2.7L V6
Axle/Gears: 4.41
In other words, I believe that the trade number of the bulb is a 37... Similar to the dash using 194s, the parking lights and brake lights using 1157s, and the rear base turn signals using 1156s.
Old Feb 23, 2013 | 09:04 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Bulb should pull out.
Old Feb 23, 2013 | 09:15 PM
insomniac's Avatar
Engine: 5.7 L98
ok im gonna try to just yank that **** with a plyers...
Old Feb 23, 2013 | 09:18 PM
85FBTranam's Avatar
Don't leave the tail of the bulb in the socket, or you'll make other issues. Good luck.
Old Feb 23, 2013 | 09:19 PM
TTOP350's Avatar
Open the jaws of the pliers wide and use some type of rubber to cushion the squeeze.
Old Feb 23, 2013 | 09:20 PM
insomniac's Avatar
Engine: 5.7 L98
needle nose?
Old Feb 23, 2013 | 09:23 PM
TTOP350's Avatar
That will break it for sure.
You could try to just use some thin rubber for extra grip.
85FBTranam's Avatar
Maybe a small pair of vice grips so you can control how much the tips close. Don't want to crush the glass.
Old Feb 25, 2013 | 09:51 PM
Roc Me 2's Avatar
Car: 1989 Iroc
They get hot and are a pain to come out but you can get it.
someone972
Aug 30, 2015 12:52 AM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
