Custom LED map light
Old Mar 14, 2013 | 05:43 PM
endlessvoid's Avatar
Car: 1989 IROC
Just finished the cover for the LED maplight that I put in with a PVC headliner. I'm so stoked about how well it turned out that I decided to make it my first post! lol
Attached Thumbnails Custom LED map light-20130314_182250a.jpg   Custom LED map light-20130314_182400a.jpg   Custom LED map light-20130314_182435a.jpg
Old Mar 14, 2013 | 10:09 PM
Car: 1989 IROC
Re: Custom LED map light
If there's any interest I could post some more pictures.
Old Mar 14, 2013 | 11:18 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Good idea.
Old Mar 15, 2013 | 01:08 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Thats pretty cool man. good job!!!!!
Old Mar 15, 2013 | 11:13 AM
Jeremy_worden's Avatar
Car: 1991 camaro RS
Engine: 3.1 v6 LHO
Transmission: 5 speed
Axle/Gears: 3.26
yes, more pics please
Old Mar 15, 2013 | 11:31 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Looks huge, whats it from?
Old Mar 15, 2013 | 11:35 AM
neeb_usmc's Avatar
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
I dig it. The factory ones are too dim
Old Mar 16, 2013 | 07:12 PM
Car: 1989 IROC
Thanks!
Here ya go (Sorry but I forgot to take any during the process):
It's not from anything, I just had to cut the PVC headliner on the t-top section to get the right fit, which is a common issue from what I've seen? So I cut out a chunk and used led strips to make a new light.
Yeah man I agree, I had wanted to do an LED overhead light anyway, and rather than try to salvage the old UV faded dome light I just figured I'd go for a more modern look.
The LED strips were just a $10 cuttable strip from dealextreme that I epoxied to the T-top crossbar where the old light socket used to sit. The cover is just a piece of plexiglass that I formed to the shape of the headliner using a heatgun, then bead blasted with a camaro logo stencil that I made on a plotter.
You can kinda see it in the pics, but the PVC headliner still sits kinda funny, with the front and the back both sloping into the center. The PVC as a headliner has a nice look but there's got to be a better way to attach it to the ceiling, it sags way too much and heavy duty velcro isn't really cutting it. I've got a couple ideas I want to try, but has anyone else found a better way to hold these things tight to the top of the car?
Attached Thumbnails Custom LED map light-20130316_185914a.jpg   Custom LED map light-20130316_185931a.jpg   Custom LED map light-20130316_185949a.jpg
Old Mar 16, 2013 | 07:17 PM
Car: 1989 IROC
a couple more
(You can kinda see what I mean about the headliner fit being off in the first shot)
Attached Thumbnails Custom LED map light-20130314_182333a.jpg   Custom LED map light-20130314_182445a.jpg   Custom LED map light-20130316_190018a.jpg
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
fonzie85
Aug 13, 2015 11:50 AM
Omega
Aug 10, 2015 12:46 PM
