Convert to Electric Speedo?
Old Mar 25, 2013 | 11:37 AM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
So my mechanical speedo has failed yet again, twice in less than 6 months. So I think I would like to try an electric speedo instead. What all is involved in the conversion when installing on carbureted engine and the reflection lighting style gauge cluster ( vs. a shine through style)
Old Mar 25, 2013 | 03:29 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Convert to Electric Speedo?
is it the speedo or the cable that failed? ive never seen the conversion on a carb car personally as guys just fix them when they break
Old Mar 25, 2013 | 07:44 PM
Dabesiv's Avatar
I haven't had time to fully diagnose it yet. From what I can tell, the cable is still firmly connected to the speedo, so it either disconnected from the trany, the cable broke, or, like last time, the gear inside the speedo that connects to the cable eroded away. I have never heard of the gears doing that before but that's what my mechanic said and I could see it eroded away. I'm not looking forward to taking it apart as I't was a pain to remove the cable last time and I had to drop the steering column and everything. This being my daily driver I really need it fixed. Might just check the local speedo shop to see what they can do.
Old Mar 26, 2013 | 01:20 PM
6SIX6's Avatar
Car: 89 IROC
All you need to do is take the dash pad off and its right there from the back of the cluster. Its pretty easy to do. If the gear is new it most likey is the cable
Old Mar 26, 2013 | 01:43 PM
Dabesiv's Avatar
I feel like a moron for never trying that, this whole time I have been tearing my hand apart trying to fit it under that cluster and all. Thanks, I will be diagnosing it today hopefully. My local speedo shop had no idea how to do a conversion either, oh well.
Old Apr 2, 2013 | 04:39 PM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
If the problem is not solved and your still interested in the electric upgrade...
I have done the conversion on my 82 bird. So once you get the electric speedo then you will need a VSS 'vehicle speed sensor'. The vss replaces the mechanical speedo sender on the side of the tranny. What i did is used a universal vss that had cable output and electric. I then connected this vss to a Dakota Digital SGI5-c converter box to make the proper signal.
So basically you need the speedo, the vss and, the dakota box. It's a pretty easy setup that has been documented a lot in this forum.
P.S. i happen to have a universal vss for sale that i no longer need since i upgraded to a t56. PM me if interested.
Old Apr 5, 2013 | 02:13 PM
Dabesiv's Avatar
Alright thanks! Im tempted to do the swap, your vss will work with any trany? For now I have the th200c but once the money is available I'll have the 700r4 and would hate to be SOL for a speedo
Old Apr 5, 2013 | 02:28 PM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
My vss is a universal unit. It screws into where your cable screws on the tranny, then you can screw the cable to it or connect the wires. Here is a pic...
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TrevinE
Sep 14, 2015 03:20 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
