How hard is it to replace the steering column housing cover & blinker switch?
Old Jul 31, 2013 | 01:26 AM
89Kicker_IROC-Z's Avatar
Car: 89' IROC-Z
Engine: HSR B2L 350ci w/LT4 hotcam and AFR 195's
Transmission: Transgo'd 700R w/Yank 2800
Axle/Gears: 9 Bolt, 3.45
My 89 was broken into and I never fixed the parts that were damaged. My steering column cover is slit open (where they tried to get to my ignition or something) and they broke the plastic wiper/blinker lever. I can still get it to work but I have to hold it funny to make the car squirt washer fluid as it is snapped around the shaft.
Is there anyway this can be fixed/replaced? Apparently I need a new cover and a blinker lever. Aftermarket levers are on ebay as well as hawks third gen but the steering column cover seems to be a wash. I have a spare cover but it doesn't seem to match the one in my car and its chewed up from removal.
Car has cruise & tilt if that makes anything easier.
*sorry for the dust, the car has been sitting for 2 years and crap tends to cling to armor-all*
Old Jul 31, 2013 | 11:42 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: How hard is it to replace the steering column housing cover & blinker switch?
Old Jul 31, 2013 | 11:43 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
www.steeringcolumnservices.com
has all the parts and diagrams you need
Old Aug 1, 2013 | 12:06 AM
Car: 89' IROC-Z
89, w/VATS, W/Tilt, NON SRS (airbag).
Mine is not listed, only 1990+ models
http://www.steeringcolumnservices.co...ats-no-srs.php
This looks to be the right one, but it says 1990-1995 Camaro & Firebird.
(However, In the link it shows 1988-1995).
Old Aug 1, 2013 | 02:45 AM
Car: 89' IROC-Z
Just bought an OEM replacement lever tonight and found one in storage from a 91 w/the yellow lettering. It probably would have saved me 70 bucks and worked just the same.
As for the columns I have, I have a few and they lack the tilt feature so the back of the plastic is different and not like my IROC.
Old Aug 1, 2013 | 09:02 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
I don't see why there may be a difference.
Best to call them direct and ask..........................
Old Aug 1, 2013 | 09:09 PM
Car: 89' IROC-Z
yep, they said it would. Ill prolly buy one from them if I cant find a better deal, 72 bucks eek.
Old Aug 2, 2013 | 09:15 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
You could send a e-mail to Denny at www.thirdgenranch.com
He may have that piece laying around ...used but cheap!
BTW: My 90 Buick winter rats column plastic is broken in the same
place but for $72 bucks and the hassle of taking the column apart
its gonna stay that way!
Old Aug 2, 2013 | 11:45 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
Little expensive but it's brand new.
http://www.classicindustries.com/fir...rts/G8078.html
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
