Dash mount rear view mirror / euro sport style
Old Aug 8, 2013 | 01:07 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Anyone seen it done in a 3rd gen?
Got a pic or done it your self?
With my notchback I moved the original mirror down a few inches but its just not enough, tired of looking up and down to see more.
Only way to get it in the right spot, is to move the stock mirror at or below halfway down the windshield. Gonna look odd form the outside since, dash mount wouldn't be noticed really. For most part it would look like I had no rear view mirror. [which is legal if you have two side mirrors]
Old Aug 12, 2013 | 07:51 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Dash mount rear view mirror / euro sport style
Tried moving the stock mirror down, got the glue for it. Says that its a permanent bond, if you do it wrong, do not remove, glue a new one over top, like its some powerful stuff.
read direction, followed, waited 30 mins, put mirror back on, it fell off windshield, started all over, let it sit 24hrs through a nice warm day, put mirror back on, it fell off, 3rd time I have glued the metal bit on, did it yesterday, gonna wait a week?
Old Aug 12, 2013 | 08:05 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
1. Tried to re-glue mine it fell off.
2. Took to a windshield glass place 1 day later it fell off.
3. They said the glass had become contaminated and
would never hold a mirror again.
4. Since it had a small crack in the corner they replaced
the windshield and it's all good.
Old Aug 13, 2013 | 02:19 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
"glass had become contaminated" how does that happen? not like its pouris
Old Aug 13, 2013 | 07:07 PM
toomany's Avatar
How are you cleaning the glass prior to sticking the base back on? What glue are you using? Alcohol wipes are good to clean with. The heat of the sun isn't the best to let them cure in, as it's usually the heat that makes them fall off in the first place.
I've done quite a few mirror re-glues and have never had a problem. I've even removed the windshield from a few afterwards and used the mirror as a handle to move it.
Old Aug 13, 2013 | 08:50 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Same deal here.
NAPA sells kits to put the mirror back on. I've used them every time and haven't had a problem yet.
Old Aug 13, 2013 | 09:10 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I've used 2 different kinds of glues over the years. One comes in a plastic tube like toothpaste or RTV and dries to a rubbery, silicone-like consistency. I let it set up overnight and the mirror fell off hours after I installed it. The second comes in a small glass vial in a cardboard sleeve with a sponge in one end. You squeeze the vial till the tube inside breaks and the glue soaks the sponge. It dries hard and clear. I've done 3 mirrors with this stuff and have never had a problem with any of them.
Old Aug 13, 2013 | 10:35 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Not sure where you would get a mirror like that, maybe a dedicated hot rod catalog or eBay. Could be expensive. Securing it to the dashboard without it wiggling around would be difficult. The dash is just a thin gauge metal with an inch of foam on top of it. I would instead look at a way to suspend the mirror further down from the headliner. basically a mirror on a pole and the pole is mounted to the roof. Only other choice would be to mount an expensive rear view mirror camera and install that.
Old Aug 13, 2013 | 11:17 PM
gt4373's Avatar
Transmission: 5-Speed Manual
I've Used This It Works Great.
Old Aug 15, 2013 | 04:39 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Attached Thumbnails Dash mount rear view mirror / euro sport style-rearview.jpg
Old Aug 15, 2013 | 04:49 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
3 days and some superglue around the edge has the permatex "sticking" but I don't adjust it without holding the base. if it falls off ill try again with better stuff. nice being able to see people, only way before they had to be right on my bumper.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Aug 14, 2015 08:25 PM
stalkier
Aug 13, 2015 12:59 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
